I'm still waiting on my H3 order. Just wanted to check here to see if any one knows if Gasohol will work in the H3 or if it will harm it?
Thanks in advance for any info. Brian |
Are you refering to E-85? If so we are the unfortunate ones.
![]() ![]() Some places this stuff is 50-70 cents a gallon cheaper ![]() E-85 is also over 100 octane though it will give you about 10% less fuel efficiency. |
Thanks for the reply Lucci,
I am have no ideaif it is also called E-85 although I do know it is made from corn. We have a local farm market that sells farm stuff, gasoline, and gasohol. I used to use it all the time in a Chevy Silverado that I had. It worked excellent. I'll do some more research on it and also ask the dealer about it. Thanks, Brian |
H3 is not e-85 approved. e-85 is 85% ethanol, 15% gasoline, and not that many vehicles can burn e-85. h3 is compatible with gasohol; 10% ethanol, 90% gasoline
H3 is not e-85 approved. </div></BLOCKQUOTE> Isn't that pretty much what I said? Anyhow <BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">not that many vehicles can burn e-85 </div></BLOCKQUOTE> All things are relative; if you mean not that many models you are correct, but there are a lot (millions) of vehicles out there that can run on E-85. Many of the vehicles that can run on it are high volume vehicles. |
