Re: Grille Guard Install - Help!
If you have a early build (Gm emblem next to H3 on door , black + silver hubcaps and no torx screw on front of tow hooks)
You either have to remove bumper to get to holding bolt through the back,or Tape off around tow hook and snap the holding clip and reverse twist off the hooks(the back bolt is not needed in reassembly)
I havent done it yet myself but use the search on top there are many threads on this subject.
List pics when your done
Good luck
