Old 04-18-2006, 03:46 PM
HummerB HummerB is offline
HummerB is off the scale
ok so i was doing some off roading and drove over this patch of super green grass near a pond and before i knew what was happening i was submerged to the doors in a sink hole. i had to call a wreker to come and pull me out with a hydraulic winch. Now i want to buy one to mount on the H3. How strong does the winch need to be and what brand should i purchase?
Birch wht (black accents/anti-bling), auto lux, oem flat side steps, oem brush guard, silver crossbars, SMA exhaust, PIAA 520 offroad lights, Valentine One.
Old 04-18-2006, 05:45 PM
Ipedog's Avatar
Ipedog Ipedog is offline
If you are able to find a mount please share the info with us!
According Ramsey Winch:
Vehicle Weight:
To calculate your vehicle's Gross Vehicle Weight (GVW), start with your vehicle's curb weight, then add the weight of the supplies and equipment you'll typically be carrying.
Line Pull:
The rated line pull of the winch must be high enough to pull your vehicle's GVW while overcoming resistance encountered when you're stuck or on an incline. Ramsey Winch recommends that you select a winch with a rated line pull at least 25% greater than your GVW.
As far as I know Warn, Ramsey, and T-Max are winches you would want to look at.
Good luck and keep us informed!
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
Old 04-19-2006, 12:30 AM
nmikes nmikes is offline
nmikes is off the scale
I havn't heard anything good about mile-marker winches... I wonder why, isn't the military using their hydraulic winches?
Old 04-19-2006, 12:06 PM
ttt
