Old 11-18-2005, 06:27 AM
Ernie Italy is off the scale
Can anyone explain what is the benefit of a AIRAID modulat intake tubes ? Ok for the filter (too big and better air). But the stock tube is not straight like AIRAID but with two other tube (as branch).. Why hummer have made a more complicated intake tubes ?
Can I have an advantage to replace the stock tube ? More power or less money in my pocket ?
Thanks.
Ernesto
Thanks.
Ernesto
Old 11-18-2005, 09:01 AM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
The MIT gives better airflow by giving a much more streamlined path from the airbox to the TB. The factory "octopus" tube is designed to eliminate some of the noise that is produced by the air intake system.
Ed
2008 H3 Alpha - Boulder Gray
Old 11-18-2005, 03:00 PM
Mr. I - Man's Avatar
Stock tube also traps water before if can get to your intake in the case of misjudging water depth
