10-22-2005, 01:56 AM
Well I know this much. K&N has been around for a long, long time and their products are race and road tested proven. I think the K&N allows alot more air intake, which some of that air is cold air could include engine radiant heat. When the hood comes down the "L" shaped wall that separates the air filter from the engine makes a box like compartment. The K&N also allows forced air from the front, and through the grille. I never seen a Volant up close and personal. But right off it looks cool and looks very enhancing to the performance to the air intake. Then I say, It looks just as restricting as the stock air intake. The stock intake is in a confind box like shape, as does the Volant. Grant it the stock air intake has baffles or a a resinator which distrupts the normal air flow to the intake manifold. I know the K&N and Volant are both better products than the stock intake. I know the Volant is more expensive and looks more astheticly better than just the K&N tube and a K&N filter. But its my opinon that the Volant looks like it makes the air harder to injest in that tight space and though it may block out hot engine air, it probably would restrict the cold air too. Versus the K&N which would allow more and all air to flow more easily. Which thats what we want is more colder unrestricting air.
I hope this helps.
Victory Red, Auto,Lux, Cashm w/ eb interior, tow pkg, BFG all terr 285/75/16 incl. spare, black side step bars, SMA chrome hood handles, Kenwood DVD, K&N Air Intake, McCulloch 8000K H.I.D. headlights, Custom made 100% sheepskin seat covers, Dual DVD headrests,SMA dual exhaust,Roof marker lights.
10-22-2005, 02:01 PM
Favorite Off Road Trips: Death Valley & Joshua Tree
Off Roaded Vehicles: H2, Yukon, Suburban, Jeep Wrangler & Unlimited
10-22-2005, 02:06 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by FLYINGBADGER2006:
I hope this helps. </div></BLOCKQUOTE>
Hey Fly,just a FYI check the bolt that holds the bracket in place on the intake.Mine fell off somehow must have loosened up somewhere along the way.
10-22-2005, 03:04 PM
Thanks for the info, much appreciated.
10-22-2005, 03:11 PM
Thanks for the heads up "1st Hummer" I will give the K&N a once over to see if anything is loose.
10-22-2005, 03:16 PM
I really wish I could hear it before I buy. I do not want my Tuff H3 to sound like a little Honda Civic I had a Z71 truck before this and I had Borla on it sounded VERY good.. I am just scared of what a 5 banger is going to sound like
 Klint T.
2007 Black Lux, Blinged out
10-25-2005, 12:45 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Captain Steve:
I installed the AirRaid system...179 bucks. Great sound and great acceleration. No engine light problem. Did finnally get it up to 105 on a long strait away. I thought there was a governor </div></BLOCKQUOTE>
I got a freak'n ticket (warning) today and have to remove my K&N and get police officer to sign off. Guess these are illegal in CA.
10-25-2005, 01:02 AM
How the heck did they know you had it? Did they make you open the hood? Ya, its a screwed deal here in Cali, you can run the filter, but can't run the complete kit. What a crock if you ask me. I think you would have to put the stock crap on when you get it smogged aswell....unless you have someone that takes a bag of pistachios to overlook those kind of mods
05-15-2006, 02:53 AM
Re: K&N installed! With pics!
Originally Posted by FLYINGBADGER2006
I purchased my K&N on ebay for $216.00. Install was no problem. Took it out for a spin after I did the install and all went fine. No rattling, no abnormal engine noise. I hope to see a slight improvent on performance and gas milage.
I am looking into Magnaflows or Borlas for a cat-back exhaust in the near future.
Hey Badger,
On the front of your K&N install, to the left of the MAS, you have a black tube coming out of a white nozzle from the intake tube. I believe the instructions mentioned that this was something to do with a fuel sensor. When I installed the FIPK, I didn't see where mine had a connection for this port sso I plugged it with the plastic bolt that K&N provided. Now that i see yours, I wonder, does the 3.5 have this sensor? Mine seems to run fine without it... BUT when it kicks in to the passing gear, it is very loud and I notice a resonance vibration of sorts. Is this normal?
Thanks,
Chris
05-15-2006, 10:47 PM
Originally Posted by H3.007
Hey Badger,
Thanks,
Chris
Chris,
Your setup is fine. The noise is normal. The stock air box along with the resonators kept the noise in pretty well.
05-16-2006, 03:07 AM
Hi Badger,
Thanks for the confirmation on my install. How about that tube sticking out of the front of yours. Is it plugged or did you have to hook it up?
Also, does anyone have any home remedies to decrease the resonance?
Thanks,
Chris
05-16-2006, 09:55 AM
hmrlvr  vbmenu_register("postmenu_107117", true);
flyingbadger, is there a cover for the K&N aircharger you installed? I saw a Volant on another thread with a cover. Apparently the cover will force the system to pull cool air from outside the vehicle instead of warm air from under the hood. I know you have a K&N but will the cooler air increase the HP more than the warmer air? Anyone have any feedback please let me know. I'm ready to order one of them and am trying to decide. Thanks
PLEASE answer a question for me (this is to all who converted air intake systems)
The factory system that comes with the H-3 already draws cool air from the right fender area, NOT FROM UNDER THE HOOD. In what way, how, explain, is the effect of the other systems besides leaving your wallet $150 to $350 dollars thinner? I'm not interested in the sound that it makes but do you get a HP gain? If you do , HOW?
RYD
05-16-2006, 01:23 PM
Hey Ducky,
There isn't a cover for the K&N that I am aware of. I think the principle is that it allows more air flow as opposed to the more restrictive factory setup. I am not sur ehow the Volant system works but it appears to feed from the factory air inlet. if this is the case, the Volant is still a restircted airflow - but I could be wrong as I have the K&N.
I did have some concern about the amount of hot air that could get into the filter over the K&N shield wall. However, it only make sense that when the vehicle is moving, the majority of the hot air will be pushed backward, away from the filter and out of the engine compartment through void venting and the such. However, I did take the precaution of buying pipe insulation (used in home plumbing applications- about $4 for a large package) and I lined the entire shield with it. The insulation is presplit and I used strips of black duck tape for further insurance against the insulation coming loose and landing on something hot or getting caught in a pully. I also figure that this will further dampen the resonance and any vibrations that may occurr.
Also, I can not tell you the specific horsepower increase but damn does it get to 80 MPH a lot quicker than it did. Mid range response is also quicker and it certainly has more power in the high end. The only downer is, again, the resonance noise when you hit the upper end. I am workign on some ideas to reduce that without ending up back to square one so I will post the results if my idea(s) are succesful. It also appears that my GPM has increased but I won't know until I hit the half-tank mark.
Hope this helps!
Chris
05-16-2006, 02:32 PM
flyingbadger, it looks like coolant is leaking from the radiator pressure cap. Recently, I noticed the same thing with my H3, but not that much. Does anyone have the same trouble ? and does anyone know what's wrong with ?
05-16-2006, 08:57 PM
I just noticed mine, yesterday. There wasn't much though.
05-16-2006, 09:05 PM
Hey Ducky,
Hope this helps!
Chris
WhiteH3 posted some dyno sheets a while ago for his K&N. I think his was one of the first and was tested by K&N. From memory, his increase was about 18ish HP in 3rd gear at the wheels. The only mod was an exhaust (Magnaflow perhaps).
05-16-2006, 11:02 PM
THE ONLY MOD WAS A PERFORMANCE EXHAUST...
AH! that only mod is a BIG mod.
as i read over this posts you all are assuming the aftermarket (k&n, others) increase HP by possibly vortexing the air, and / or cooling the air, YES???
As I read the lit on the k&n and others they take about the cooler air they are allowing into the system, unlike the factory system. Again the H-3 uses cooler air so please inform me again what i am missing...
THANKS
RYD
05-17-2006, 08:03 PM
Ducky. You’re right about the H3. It already pulls in cool air from the outside. But the K&N and Volant intake systems don’t provide a swirling effect and don’t actively cool the air. They only provide these benefits.
1. The oiled cotton filter element is less restrictive than the OEM dry paper element. The element is also shaped as a 360 degree conical filter for smoother and more uniform airflow into the intake tube (square intake filters can create eddies).
2. The intake tubes are optimized for maximum airflow. They are mandrel bent to maintain uniform tube diameter. This helps prevent unintended pressure waves that could impede airflow. Also, based on extensive testing, the diameter and length of the intake tube is designed to optimize air velocity and pressure waves.
3. The filter elements are enclosed to separate them from engine heat. The stock airbox already does this, but many aftermarket systems omit the enclosure to save money.
4. The filters are washable and reusable (when properly re-oiled)
Stay away from cheap shiny systems with open elements. They can actually rob you of power.
05-17-2006, 08:23 PM
There are also disadvantages to using an oiled cotton filter element.
1. They don't filter as well as a dry paper element until they collect a little dirt ... even then, they allow more fine particles into your engine than paper.
2. They must be cleaned gently before reuse, or you can damage the filter material.
3. When re-oiling the filter, adding too little oil compromises filtration. Adding too much oil can damage your MAF sensor.
4. They're noisier than the stock system.
Although it's a fact that wet filters allow greater airflow, there's some debate about how much air a non-turbo, non-s/c engine needs, as well as the location in the powerband where the advantage occurs compared to where the power is needed.
Here's a technical report comparing wet and dry air filters http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Here's a link to a high-flow dry filter system that I'm researching. Supposedly it has all the advantages of the oiled filter and fewer of the disadvantages. http://trucks.aempower.com/
