02-06-2005, 02:11 AM
Here is another pic of my 03 H2.
Tim Andrews 03 Black H2 lux
02-06-2005, 02:17 AM
One more
02-06-2005, 02:19 AM
Here is one more
02-06-2005, 02:30 AM
Very nice! Off-roading MAX-BLING!
02-06-2005, 02:33 AM
Hey man. Try 640x480 max pic size next time. Couldn't scroll far enough to see the whole picture.
Jonahs
02-06-2005, 02:44 AM
Hi SFOX The Diff cover is made by a company called PML you can find them at yourcovers.com it goes for $175.00 I put it on when I swapped the gears out to 4.88's. And how do I change the picture size to 640x480? Any help would be appreciated. And thank you all for your nice comments.
02-06-2005, 02:50 AM
One more pic this was at the end of the trip in Hotsprings Va
02-06-2005, 03:05 AM
Tim. Don't know what application you're using for the pics but all have the ability to resize. Even in MS Paint select image/stretch/skew and alter size. Nice looking rig!
Jonahs
02-06-2005, 03:26 AM
Thank you Jonahs for the help and complements I resized this one hope it works
02-06-2005, 03:34 AM
Here is a closer look at the differential cover
02-06-2005, 03:43 AM
Great pics. Black looks awesome brown.
To do a simple resize, go here to the Microsoft Image Resizer and download:
http://download.microsoft.com/downlo...ertoySetup.exe
Simply right click the image and choose the smallest available. Then delete the original if you want, but be sure to post the "small" pic.
02-06-2005, 03:54 AM
Thanks KenP that was pretty painless
02-06-2005, 03:55 AM
Thank you KenP that was pretty painless
02-06-2005, 04:11 AM
I think I have the hang of it now thanks again for the info.
02-08-2005, 04:17 AM
what are you running for wheels and tires, also lift?
Andre
02-08-2005, 11:53 AM
Hi Andre I am running a FABTECH 6 inch lift with Multiple front shock system and FABTECH skid plates and duel steering stabilzers. The gears were swapped out to 4.88 with a e-locker in the front. The wheels are MKW 20x11 the tires are 39x13.50x20 IROC radials. Since that photo I have changed the trailing arms and panhard rod. Also running HOTCHKIS front and rear sway bars. When the tie rods come in at fabtech I will be replacing those along with the pitman arm and idler arm. I have a set of fox racing shocks with remote resevoirs I have not had time to install yet.
02-08-2005, 07:49 PM
Blown that is a nice truck!  Did you have to cut anything with the Fabtek?
02-09-2005, 06:36 PM
Hi 1BADH2 I used to have the same plate on my Dodge but it said 1BADRAM. You have to cut the ear off the front differential houseing and there is some minor welding. If you go to the FABTECH website you can download the instructions. Thank you for the complement also.
