06-29-2005, 04:35 PM
i tried searching and couldnt find anything.i took a quick look along the drivers side frame rail and didnt see it,can someone tell me where it is?
white 03 lux-gone
black 06 lux sut
white 03 lux-gone
black 06 lux sut
06-29-2005, 05:24 PM
It's mounted to the outside of the drivers side frame between the fuel tank and engine.
Jonahs
06-29-2005, 05:29 PM
Fram G9344. Having one to look at may help you find it.
06-29-2005, 06:01 PM
FYI 04 and up h2's do not have a serviceable fuel filter. The only filter is in the tank and not serviceable.
06-29-2005, 06:13 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hummertech:
FYI 04 and up h2's do not have a serviceable fuel filter. The only filter is in the tank and not serviceable. </div></BLOCKQUOTE>Come again!
No replacing a fuel filter? Really? I wonder why they did that?
06-29-2005, 06:31 PM
Come again, again? For '03
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Description and Operation
FUEL STRAINER
The fuel strainer attaches to the lower end of the fuel sender. The fuel strainer is made of woven plastic. The functions of the fuel strainer are to filter contaminants and to wick fuel. Fuel stoppage at this point indicates that the fuel tank contains an abnormal amount of sediment.
IN-LINE FUEL FILTER
The fuel filter is located in the fuel feed pipe, between the fuel pump and the fuel injectors. The paper filter element (2) traps particles that may damage the fuel injection system. The filter housing (1) is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. </div></BLOCKQUOTE>
Jonahs
06-29-2005, 06:34 PM
Come again, again, again? For '03
FUEL FILTER REPLACEMENT
REMOVAL PROCEDURE
IMPORTANT: Inspect the fuel tank internally and clean the fuel tank if you find a restricted fuel filter.
1. Relieve the fuel system pressure.
2. Raise the vehicle.
3. Clean all the fuel filter connections and the surrounding areas before disconnecting the fuel pipes in order to avoid possible contamination of the fuel system.
4. Disconnect the threaded quick connect fittings from the fuel filter.
5. Remove the fuel filter bracket bolt.
6. Cap the fuel pipes in order to prevent possible fuel system contamination.
7. Slide the fuel filter from the bracket.
8. Inspect the fuel pipe O-rings for cuts, nicks, swelling, or distortion. Replace the O-rings if necessary.
INSTALLATION PROCEDURE
1. Slide the fuel filter into the bracket.
2. Remove the caps from the fuel pipes. NOTE: Refer to Fastener Notice in Service Precautions.
3. Connect the quick connect fittings (1, 2) to the fuel filter.
4. Lower the vehicle.
5. Tighten the fuel filler cap.
6. Connect the negative battery cable.
7. Use the following procedure in order to inspect for leaks:
7.1. Turn ON the ignition, with the engine OFF, for 2 seconds .
7.2. Turn OFF the ignition for 10 seconds .
7.3. Turn ON the ignition, with the engine OFF.
7.4. Inspect for fuel leaks.
8. Install the engine sight shield.
Jonahs
06-29-2005, 07:00 PM
FYI 04 and up h2's do not have a serviceable fuel filter. The only filter is in the tank and not serviceable. </div></BLOCKQUOTE>Acoording to http://www.fram.com/ they have a serviceable filter.
ExtraGuard PH3506
ToughGuard TG3506
DoubleGuard ----------
X2 ----------
Air Filters ----------
Misc. Filters ----------
Fuel Filters G9344
PCV Valves ----------
Transmission Filters FT1217
w/ Deep Pan; 4L60-E
Trans. Modulators ----------
AirHog ----------
Tough Guard Air ----------
High Mileage Filter HM3506
Now it's interesting that the Fram number, and WIX number (33129) cross to a Delco GF831 which, according to the Delco site, only fits '03. Odd.
http://www.wixfilters.com/filterlookup/index2.asp?Secti...del=-1&TempYear=2005
06-29-2005, 07:52 PM
Hummertech is correct, in 04 GM went to a returnless fuel system on all of their fullsize trucks. The only filter you will find is in the tank with the pump.
06-29-2005, 08:29 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummMe:
Hummertech is correct, in 04 GM went to a returnless fuel system on all of their fullsize trucks. The only filter you will find is in the tank with the pump. </div></BLOCKQUOTE>So is the "filter" in the tank a real filter, or a sock? The sock style won't do much for small particles.
Man, that sucks for you guys if anything foreign gets in those tanks.
06-29-2005, 09:42 PM
Man, that sucks for you guys if anything foreign gets in those tanks.  </div></BLOCKQUOTE>Screw yo..... Oh yeah! I have a '03. He's right that really sucks for you guys.
