Old 03-10-2006, 09:22 PM
ratesguy ratesguy is offline
ratesguy is off the scale
My driver side door panel tray(you know, at the bottom) has cracked in half right in the middle and down the bottom. Of course you can only buy the door panel as a whole and it is 675 bucks. This is an 03 h2. Anyone know where any wrecked H2's are?
Old 03-11-2006, 12:31 AM
VTSTOMPER is off the scale
Your best bet is to call some salvage yards.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 03-11-2006, 12:55 AM
tomp's Avatar
tomp tomp is offline
A lot of times these things can be repaired by your friendly neighborhood Dr. Vinyl repair man. See if you have one in your area, or similar repair options.
Old 03-11-2006, 01:44 AM
That sounds like a do-it-yourselfer. Just get some clear epoxy and apply from the inside. If it doesn't work you're out a couple bucks.
Old 03-15-2006, 05:56 PM
Thanks, gonna go the DIY route and try the epoxy
Old 03-18-2006, 03:33 PM
</table></tr><table width=1000><table>
</TD></TR>
<TR>
<TD class=cutline>Being stupid can have consequences, as Illiana Hummer Club member Roberto Rios of Crete found out after running aground and getting wedged against a tree on Friday while trying to follow more experienced Hummer owners through the Badlands Off-Road Park in Attica, Ind. The group was at the park to search for trails and clear paths in preparation for the Hummer Club's national event in May.</TD></TR></table>
