Old 04-26-2006, 11:41 PM
when i installed the k%n cold air intake i disconnected the battery via the instructions that came with k%n , i previously re-programmed the truck with hyper-tech, when i disconnnected the battery did i re-set the factory computer to "cancel" the hypertech program i installed?
Old 04-27-2006, 12:27 AM
Screeper's Avatar
Screeper Screeper is offline
Screeper is an unknown quantity at this point
No you did not. The factory program is inside your hypertech right now. You can always check by plugging back in the hypertech and it will display "programming installed" Its all good
Old 04-27-2006, 12:52 AM
THANKS, i just read an earlier post saying something about when the battery is unhooked and placed back , it automatically resets to the factory settings
Old 04-27-2006, 12:57 AM
just quit, walk away and quit
Old 04-27-2006, 01:34 AM
hey paragon , what did i tell you about typing while my dikk is in your mouth?
Old 04-27-2006, 01:42 AM
duh huh
Old 04-27-2006, 03:39 AM
tomp's Avatar
tomp tomp is offline
ECMs contain a base Air/Fuel & timing table stored in the ECMs ROM. It will be there even if power is removed. It doesn't matter if this is the OEM map or one from Hypertech.
There is also some AFR customization that occurs depending on data the ECM received from sensors (MAF, O2, TP sensor etc.). This is what gets reset after disconnecting the battery. This is needed to compensate for dynamic variables because every engine is different and experiences numerous changes throughout it's lifespan.
Old 04-27-2006, 03:50 AM
Your homoerotic fantasies are creepy. Keep 'em to yerself, k?
Old 04-28-2006, 11:22 PM
U ARE NOT WORTHY OF A CHUCK NORRIS AVATR, GO HOME
Old 04-28-2006, 11:44 PM
MarineHawk's Avatar
Are you worthy of the nothingness you have for an avatar?
Old 04-29-2006, 01:48 AM
UR UP PARAGONS ASS TOO?
Old 04-29-2006, 02:03 AM
Yuz an idiot. Why iz ya even up in chere? If yuz can'ts work das shiat jus chunk it. Aight?
Old 04-29-2006, 02:13 PM
DUH HUH, is that a pic of u in ur avtr? how gay is ur pic?
Old 04-29-2006, 02:40 PM
Mr. I - Man's Avatar
Lets look at Monstermatt for a moment,
Screen Name - Monstermatt - Matt is a Monster
Drives a ficticious H2- a big truck
I guessing this guy is trying hard to over compensate and has homoerotic fantisies of men Paragon in paticular.
This guy is probably about 5'2"- 5'3" 115-135 soaking wet, lacked a father figure and probably was picked on in his early teens and still shunned by females till this day. This is was causes his rage and attatchment to males in the mid 30's to upper 40's he just wants a daddy!
Old 04-30-2006, 12:36 AM
NICE PROFILE, GEEK
Old 04-30-2006, 05:10 AM
NICE PROFILE, GEEK
Yeah, it is about realistic as you being heterosexual and owning a hummer. Go away kid, go find your daddy!!
Old 04-30-2006, 05:15 AM
Is this profile better????
Old 05-01-2006, 12:54 AM
TOOL!!
Old 05-01-2006, 06:47 PM
Aw come on dawg, Dont be hatin
Old 05-02-2006, 12:26 AM
IF U WANNA DISH IT OUT , BE READY TO TAKE IT!! that goes for paragon too
