Old 06-06-2003, 11:44 PM
buddy buddy is offline
buddy is off the scale
Has anyone noticed the roar that comes when the fan clutch engages. It seems like my clutch fan doesn't want to disengage as rpm's increase.
At high rpm's the clutch will finally disengage and everything is fine until you stop and accelerate again. I've replaced fan clutches before, but usually on high mileage vehicles.
I have no overheating problems, temps always at 210. Manual says that's normal operating temp..I would perfer 180.
What you think? Normal for this vehicle with higher coolant temps? Clutch fan going bad?
Buddy
Buddy
Old 06-07-2003, 12:15 AM
TBarrow TBarrow is offline
TBarrow is off the scale
Watch your guage as I was told it was not a sweep hand. It will move stop and then move again and rest at 210. The fan is loud until you get moving good and the clutch lets go.
Old 06-07-2003, 01:09 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
Buddy...
Sounds normal for the H2. I have noticed more fan noise than usual on mine also. Since the weather has warmed up it runs alot more and stay on longer than it did during cooler temps.
The H2 has a pretty tight engine compartment which will contribute to the fan running longer, also no air dams under the H2 to create a negative pressure to help pull the air through and exit out underneath the vehicle.
Don
Old 06-07-2003, 04:02 PM
Thanks for the replies. I was hoping it was the weather and/or design of the H2 and not the fan clutch. As long as it's the norm, I'm okay with that.
Buddy
