Old 04-18-2005, 12:24 PM
partsguy partsguy is offline
I believe Spike has the information you need. <BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> </div></BLOCKQUOTE>LR outer 15060525
RR outer 15060526
Center (3) 15105495
Think I'm safe Spike Could be a frog set up!
Couldn't resist. I am sure someone will supply you with part numbers and options on the lights.
It sounds like your bar slid out the back of the rails, which is how you would have taken it off. There were some caps on the back ends of those rails but are probably missing now. The bar's sides just slide (from the back) back into the slides and you tighten them down. </div></BLOCKQUOTE>
