Old 06-04-2005, 12:11 AM
JohnnyRPM's Avatar
JohnnyRPM JohnnyRPM is offline
JohnnyRPM is off the scale
My H2 has been showing the check engine light for 4 days now. Runs perfectly and still gets about 12.4 mpg. Gas cap is tight and I've definitely got three diagnostic cycles under me. Haven't disconnected the battery yet to try to reset it but honestly I'd like to know what it is before I reset it.
I know on older GM cars you could short out two terminals on the diagnostic connector with a paperclip and the check engine light would flash the code that it's throwing instead of using a scan-tool. Can this be accomplished on the H2? Trying to avoid buying a scan tool or programmer and I'd love to avoid the hassle of a dealer visit if it's a sensor of some sort I could replace myself.
Thanks,
-John
JohnnyRPM's Avatar
Thanks,
-John
Old 06-04-2005, 01:26 AM
h2sin h2sin is offline
h2sin is off the scale
OBD II code has to be checked using a scan tool I believe. I know places like Auto Zone will check your code free of charge but I would not recommand using any aftermarket components especially if you can get it done for "FREE" at your local Hummer Dealer... unless its out of warranty use genuine GM parts
Old 06-04-2005, 01:29 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by JohnnyRPM:
-John </div></BLOCKQUOTE>
You had a Fiero too huh?
I get that when I powerwash my engine some times. I just disconnect/reconnect the battery terminal.
Old 06-04-2005, 01:59 AM
Hummie2's Avatar
Hummie2 Hummie2 is offline
Onstar can run remote diagnostics and give you a code number. Have you been in deep water/mud lately? If so charcoal cannister/cannister purge valve will plug up with mud and require cleaning or replacing and set a code.
Old 06-04-2005, 10:00 AM
JohnnyRPM's Avatar
I get that when I powerwash my engine some times. I just disconnect/reconnect the battery terminal. </div></BLOCKQUOTE>
'85 GT.....LOVED that car. Too bad all my friends used to make fun of me.
I'll try disconnecting and resetting it. If not, maybe I'll break down and buy a scan tool.
Thanks gang...
-John
Old 06-06-2005, 11:25 PM
Bigdaddy Bigdaddy is offline
Bigdaddy is off the scale
if you remove the battery cables for 15 minutes everything should reset. however, i would check the code first as you may need some type of reprogram on the computer
Old 06-07-2005, 12:10 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bigdaddy:
if you remove the battery cables for 15 minutes everything should reset. however, i would check the code first as you may need some type of reprogram on the computer </div></BLOCKQUOTE>Remove both cables? Really?
Need to reprogram the computer?........ because of the code...... are you dumb?
Old 06-07-2005, 12:16 AM
Ahhhh ya ****ed now boiee!
