Old 06-19-2004, 04:23 PM
Kevin B Kevin B is offline
Kevin B is off the scale
Is anyone running 17x10 inch rims with no lift? If so do you have issues with rubbing? I am considering 10 inch wide rims with 37x12.5 BFG's
Old 06-20-2004, 09:26 AM
Bevo Bevo is offline
Bevo is off the scale
My stock rims and tires rub on the sway bar at full lock on both sides.
Yellow 03 Adventure w/black Grill, UM8 Touch Screen Navigation Radio, U2K XM Digital Radio, Remote 6-CD Changer, JBA Titanium Headers, Corsa Off-Road Sport, Airaid Filter & MIT, Nology Wires & Plugs, S&P Pro-Flash, Warn 9.5ti w/X-Line, Toyo Open Country M/T 37x13.5.
Old 06-20-2004, 04:45 PM
kdio kdio is offline
kdio is off the scale
I have run 17x10 rims and 37x12.50x17 Goodyear MTR for 27,000 miles with no rubbing. Even offroading they do not hit. I adjusted the torsion bars to raise the front end, but my H2 sat very nose low when I bought it. The rims have a 4.5 inch backset.
Old 06-20-2004, 07:28 PM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
Hey Bevo,
If your "stock" setup rubs on the sway bars I'd get it checked out before the warranty expires.
2003 Yellow H2 LUX (Sold)
Old 06-21-2004, 12:37 AM
kdio, that is the set up I was thinking about, but then I found a set of 17x8 with funtioning bead locks and I am wondering if that might be a better way to go. Im thinking the sidewall movement might be helped with the 8" rims. Too many decisions!
I know, I know, bead locks are not D.O.T. approved but with all the fake ones these days im sure no one will even notice .
Thanks for the info and your expierence should I go with the 10's
