Old 02-05-2006, 07:52 PM
NSANE NSANE is offline
NSANE is off the scale
I'm looking for some ideas on were to mount my brake cobtroler? I'm like 6'3" tall and was thinking down above the gas pedal, but I thought I would see if anyone had a better idea. Thanks!
2006 H2, Black with bling!!
Old 02-05-2006, 07:59 PM
shipbldr shipbldr is offline
shipbldr is off the scale
How about in the glove box or center console?
Old 02-05-2006, 08:20 PM
I thought of the console, but it has to be mount with-in -20 to +70* facing forward. I just hate to hang it under the steering wheel. I may just have too. Thanks
Old 02-05-2006, 08:41 PM
Do you just need to see it or are there controls on it you need to reach?
Old 02-05-2006, 09:54 PM
MSeeb MSeeb is offline
MSeeb is off the scale
You really need to mount it where you can reach it. Heres a couple of pics showing where I mounted mine. I am only 5'11 but it works out fine for me. No leg clearance issues at all.
Old 02-05-2006, 09:55 PM
Pic 2
Old 02-06-2006, 01:22 AM
Thanks MSeeb for the picures, that helps! I think thats were I'll be putting mine too.
Old 02-06-2006, 01:23 AM
tomp's Avatar
tomp tomp is offline
NOTE: 2006 models use a different trailer wiring adapter than previous years! Make sure to get one from Hummer for 2006 models as the pin-outs are different!
Old 02-06-2006, 01:43 AM
Thanks and yes I got the one in the trailer kit with the truck.
Old 02-06-2006, 01:50 PM
tomp's Avatar
Call Peter at Sewell Hummer in Plano Parts Dept and he can explain. He is the one who looked it up for me when I told him the pin-outs were different on the 2006 model.
Had I known at the time, I would have documented the wiring I ended up with. I had to use a meter and tone each wire.
GOod thing you can remove the pins from the connector and put them in their proper place.
Old 02-06-2006, 07:34 PM
do it like this
Old 02-06-2006, 07:47 PM
alldunn's Avatar
alldunn alldunn is offline
alldunn is off the scale
do it like this
</div></BLOCKQUOTE>
That's a nice crack on the windshield.
Black Lux H2
Old 02-06-2006, 07:49 PM
Hurricane Katrina
Old 02-08-2006, 10:42 AM
GOod thing you can remove the pins from the connector and put them in their proper place. </div></BLOCKQUOTE>
Ok, I found out that there is chance my kit is from a 05. Does anyone the right wiring for the 06 so I can ckeck it? Thanks
Old 02-09-2006, 02:07 AM
Well I have it all installed. I checked all the wires and it must have been the right plug. I ended up with it installed the same place as MSeeb. Thanks guys for the input!
Old 02-09-2006, 02:31 AM
usmctopgun usmctopgun is offline
usmctopgun is off the scale
Anyone have the part number for the harness for an '05?
Semper Fi,
Michael
Old 02-09-2006, 02:33 AM
tomp's Avatar
Did you test it towing trailer with brakes? I know that the wire guages are different sizes on the Z-82 wiring adapter for a very good reason. I also know that they are labeled wrong for a 2006 H2.
I had a Chevy 2500HD with the Z-82 harness installed and attached to my brake controller. The harness that came out of my truck is exactly the same one that Hummer sells. When I removed it out of my truck and plugged it into the H2, it did not work. I had to figure it out myself as Hummer did not yet make one for the 2006 H2.
What I had to do was to remove all of the pins out of the connector, tone out each pin under the H2 dash using my meter, then re-install the pins in the proper places. It now works like it suppose to.
