Old 01-28-2006, 07:13 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Over the past week, I have been getting a bit of slip when taking off from a stop, like I was taking off in 2nd or 3rd gear, but within a foot or so, first gear would engage and all would be well. Today, though, it's like I completely lost 1st gear, maybe 2nd too. I stopped and put it in 1st gear, no problem. Then 2nd gear from a stop, no problem, but then a healthy slip when changing to third while rolling.
I'll be taking it in to the stealer (sic) on Monday, but wanted to see if anyone had any similar problems or any advice.
Thanks,
Pete
TXSUT's Avatar
Thanks,
Pete
Old 01-28-2006, 07:18 PM
VTSTOMPER is off the scale
Oh man...very sad news - keep us posted TXSUT.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 01-28-2006, 07:43 PM
TXSUT's Avatar
J, feel free to call me Pete in public. LOL
Yeah, I'm BUMMED!
I just ran a diagnostic check with my Superchips programmer, and got the follwoing codes:
#1) P0740 - Torque Convertor Clutch Circuit Malfunction
#2) P0785 - Shift Timing Solenoid Error
I'm on my fourth of many beers to come, gonna drown my sorrows.
Old 01-28-2006, 09:50 PM
PETE LOL , press the onstar button - have them run a test too!!!! I'd like to see what they say...
Old 01-28-2006, 10:26 PM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2900.2802" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 828044
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM>
<HR>
</FORM>
<H1>DTC P0740</H1>
[img]Service Information_files/TifToGif.gif[/img]
<MAP name=885563.map><AREA
shape=RECT alt="Master Electrical Component List" coords=546,0,579,33
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=841408&amp;pubid=293&amp;evc=s m"><AREA
shape=RECT alt="Automatic Transmission Controls Schematics"
coords=546,33,579,66
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=832070&amp;pubid=293&amp;evc=s m"><AREA
shape=RECT alt="OBD II Symbol Description Notice" coords=546,66,579,99
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=17618&amp;pubid=293&amp;evc=sm "></MAP><A
name=ss1-828044><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#ss1-828044">
<H5>Circuit Description</A></H5>
The torque converter clutch (TCC) solenoid valve is an electrical device that
is used with the torque converter clutch pulse width modulation (TCCPWM)
solenoid valve in order to control TCC apply and release. The TCC solenoid valve
attaches to the transmission case assembly extending into the pump cover. The
TCC solenoid valve receives ignition voltage through the Ignition0 voltage
circuit. The powertrain control module (PCM) controls the solenoid by providing
the ground path on the TCC solenoid valve control circuit. The PCM monitors the
throttle position sensor voltage, the vehicle speed, and other inputs in order
to determine when to energize the TCC solenoid valve.</P>
When the PCM detects a continuous open, short to ground or short to power in
the TCC solenoid valve circuit, then DTCP0740 sets. DTCP0740 is a
typeBDTC.</P><A name=ss2-828044><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#ss2-828044">
<H5>Conditions for Running the DTC</A></H5>
<UL type=BULLET>
<LI>The system voltage is 10-18volts.
<LI>The engine speed is greater than 450RPM for 5seconds.
<LI>The engine is not in fuel cutoff. </LI>[/list]<A name=ss3-828044><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#ss3-828044">
<H5>Conditions for Setting the DTC</A></H5>
DTCP0740 sets if one of the following conditions occurs for
5seconds:</P>Condition 1
The PCM commands the solenoid ON and the voltage feedback remains high,
B+.</P>Condition 2
The PCM commands the solenoid OFF and the voltage feedback remains low,
0volt.</P><A name=ss4-828044><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#ss4-828044">
<H5>Action Taken When the DTC Sets</A></H5>
<UL type=BULLET>
<LI>The PCM illuminates the malfunction indicator lamp (MIL) during the second
consecutive trip in which the Conditions for Setting the DTC are met.
<LI>The PCM inhibits TCC engagement.
<LI>The PCM inhibits 4th gear if the transmission is in hot mode.
<LI>The PCM freezes transmission adapt functions.
<LI>The PCM records the operating conditions when the Conditions for Setting
the DTC are met. The PCM stores this information as Freeze Frame and Failure
Records.
<LI>The PCM stores DTCP0740 in PCM history during the second consecutive
trip in which the Conditions for Setting the DTC are met. </LI>[/list]<A
name=ss1-651481><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#ss1-651481">
<H5>Conditions for Clearing the MIL/DTC</A></H5>
<UL type=BULLET>
<LI>The PCM turns OFF the MIL during the third consecutive trip in which the
diagnostic test runs and passes.
<LI>A scan tool can clear the MIL/DTC.
<LI>The PCM clears the DTC from PCM history if the vehicle completes 40
warm-up cycles without an emission-related diagnostic fault occurring.
<LI>The PCM cancels the DTC default actions when the ignition switch is OFF
long enough in order to power down the PCM. </LI>[/list]<A name=ss5-828044><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#ss5-828044">
<H5>Diagnostic Aids</A></H5>
With the TCC engaged, the TCC slip speed should be -20 to +50RPM.</P><A
name=ss6-828044><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#ss6-828044">
<H5>Test Description</A></H5>
The numbers below refer to the step numbers on the diagnostic table.</P>
  1. <A name=TD04>
    <LI value=4>
    This step tests for voltage to the solenoid.</P><A name=TD05>
    <LI value=5>
    This step tests the ability of the PCM and wiring to control the ground
    circuit.</P><A name=TD07>
    <LI value=7>
    This step tests the resistance of the TCC solenoid valve and the automatic
    transmission (AT) wiring harness assembly.</P></LI>
<TABLE width="100%" border=1></A><A name=tab7-828044><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#tab7-828044">
<H4><FONT color=#254164>DTC P0740</FONT></H4></A>
<TBODY>
<TR>
<TH vAlign=bottom align=middle>
Step</P></TH>
Action</P></TH>
Value(s)</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
<TD vAlign=center align=middle><A name=S01>
1</P></A></TD>
<TD vAlign=top align=left>
Did you perform the Powertrain Diagnostic System Check?</P></TD>
--</P></TD>
<TD vAlign=bottom align=middle>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S02">Step
2</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30550&amp;RefDoc=828044&amp;evc =sm">Diagnostic
System Check - Engine Controls</A> in Engine Controls - 6.0L
(LQ4)</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S02>
2</P></A></TD>
  1. <LI type=1>Install a scan tool.
    <LI type=1>Turn ON the ignition, with the engine OFF.
    <FONT color=brown>
    <H4>Important</H4>
    Before clearing the DTC, use the scan tool in order to record the
    Freeze Frame and Failure Records. Using the Clear Info function erases
    the Freeze Frame and Failure Records from the PCM.</P></FONT>
    </P>
    <LI type=1>Record the DTC Freeze Frame and Failure Records.
    <LI type=1>Clear the DTC. </LI>
Are any of the following DTCs also set?</P>
<UL type=BULLET>
<LI>P0753
<LI>P0758
<LI>P0785
<LI>P1860 </LI>[/list]</TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S03">Step
3</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S04">Step
4</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S03>
3</P></A></TD>
Inspect the IGN0 fuse for an open.</P>
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62113&amp;RefDoc=828044&amp;evc =sm">Circuit
Protection - Fuses</A> in Wiring Systems.</P>
Is the fuse open?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S09">Step
9</A> </P></TD>
Go to <A
<TR>
<TD vAlign=center align=middle><A name=S04>
4
</P></A></TD>
  1. <LI type=1>Turn OFF the ignition.
    <LI type=1>Disconnect the AT inline 20-way connector, additional DTCs
    may set.
    <LI type=1>Install the <A
    href="http://127.0.0.1:9001/servlets/RetrieveTif?pic=537322">J
    44152</A> Jumper Harness (20 pins) on the engine side of the AT inline
    20-way connector.
    <LI type=1>Using the <A
    href="http://127.0.0.1:9001/servlets/RetrieveTif?pic=8917">J
    35616-A</A> GM Terminal Test Kit, connect a test lamp from
    terminalE of the <A
    44152</A> to ground. Refer to <A
    href="http://127.0.0.1:9001/servlets/CellHandler?CellId=75943&amp;RefDoc=828044&amp;evc =sm">Automatic
    Transmission Inline 20-Way Connector End View</A> . </LI>
Does the test lamp illuminate?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S05">Step
5</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S12">Step
12</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S05>
5
</P></A></TD>
  1. <LI type=1>Connect the test lamp from terminalE to terminalT
    of the <A
    44152</A> . Refer to <A
    <LI type=1>Use the scan tool in order to command the TCC solenoid valve
    ON and OFF three times. </LI>
Does the test lamp turn ON and OFF with each command?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S07">Step
7</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S06">Step
6</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S06>
6</P></A></TD>
Is the test lamp always ON?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S13">Step
13</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S14">Step
14</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S07>
7
</P></A></TD>
  1. <LI type=1>Install the <A
    44152</A> on the transmission side of the AT inline 20-way connector.
    <LI type=1>Using the DMM and the <A
    35616-A</A> , measure the resistance between terminalsT and E of
    the <A
Does the resistance measure within the specified range?</P></TD>
21-33ohms</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S08">Step
8</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S15">Step
15</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S08>
8</P></A></TD>
  1. <LI type=1>Measure the resistance from terminalE of the <A
    <LI type=1>Measure the resistance from terminalT of the <A
    44152</A> to ground. </LI>
Do both readings measure greater than the specified value?</P></TD>
250Kohms</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30126&amp;RefDoc=828044&amp;evc =sm">Intermittent
Conditions</A> in Engine Controls - 6.0L (LQ4)</P></TD>
Go to <A
<TR>
<TD vAlign=center align=middle><A name=S09>
9</P></A></TD>
<FONT color=brown>
<H4>Important</H4>
The condition that affects this circuit may exist in other connecting
branches of the circuit. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61979&amp;RefDoc=828044&amp;evc =sm">Power
Distribution Schematics</A> in Wiring Systems for complete circuit
distribution.</P></FONT>
</P>
Test the Ignition0 voltage circuit (CKT1020) of the TCC
solenoid valve for a short to ground between the fuse block and the AT
inline 20-way connector.</P>
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62110&amp;RefDoc=828044&amp;evc =sm">Testing
for Short to Ground</A> and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61965&amp;RefDoc=828044&amp;evc =sm">Wiring
Repairs</A> in Wiring Systems.</P>
Did you find and correct the condition?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S17">Step
17</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S10">Step
10</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S10>
10</P></A></TD>
<FONT color=brown>
<H4>Important</H4>
</P>
Test the Ignition1 voltage circuit (CKT839) of the TCC
solenoid valve for a short to ground between the AT inline 20-way
connector and the TCC solenoid valve.</P>
Refer to <A
for Short to Ground</A> in Wiring Systems.</P>
Did you find a short to ground condition?</P></TD>
--</P></TD>
Go to <A
15</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S11">Step
11</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S11>
11</P></A></TD>
  1. <LI type=1>Test each solenoid for a short to ground.
    <LI type=1>Replace the faulty solenoid as necessary. </LI>
Did you complete the replacement?</P></TD>
--</P></TD>
Go to <A
17</A> </P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S12>
12</P></A></TD>
<FONT color=brown>
<H4>Important</H4>
</P>
solenoid valve for an open.</P>
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62109&amp;RefDoc=828044&amp;evc =sm">Testing
for Continuity</A> and <A
--</P></TD>
Go to <A
17</A> </P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S13>
13</P></A></TD>
Test the control circuit (CKT422) of the TCC solenoid valve for a
short to ground between the PCM connector C2 and the AT inline 20-way
connector.</P>
Refer to <A
--</P></TD>
Go to <A
17</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S16">Step
16</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S14>
14</P></A></TD>
an open or short to power between the PCM connector C2 and the AT inline
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62194&amp;RefDoc=828044&amp;evc =sm">Circuit
Testing</A> and <A
--</P></TD>
Go to <A
17</A> </P></TD>
Go to <A
<TR>
<TD vAlign=center align=middle><A name=S15>
15</P></A></TD>
Replace the AT wiring harness assembly, this includes the TCC solenoid
valve.</P>
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=6963&amp;RefDoc=828044&amp;evc= sm">Valve
Body and Pressure Switch Replacement</A> .</P>
--</P></TD>
Go to <A
17</A> </P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S16>
16</P></A></TD>
Replace the PCM.</P>
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30267&amp;RefDoc=828044&amp;evc =sm">Powertrain
Control Module (PCM) Replacement</A> in Engine Controls - 6.0L (LQ4).</P>
--</P></TD>
Go to <A
17</A> </P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S17>
17</P></A></TD>
<TD>
Perform the following procedure in order to verify the repair:</P>
  1. <LI type=1>Select DTC.
    <LI type=1>Select Clear Info.
    <LI type=1>Drive the vehicle in D4 with the TCC ON and OFF. Ensure that
    the following conditions are met:
    <UL type=BULLET>
    <LI>The PCM commands the TCC solenoid valve ON, and the voltage
    feedback drops to zero.
    <LI>The PCM commands the TCC solenoid valve OFF, and the voltage
    feedback increases to B+.
    <LI>All conditions met for 5seconds. </LI>
<LI type=1>Select Specific DTC.
<LI type=1>Enter DTCP0740. </LI>[/list]
Has the test run and passed?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=828044&amp;psdid=293&amp;evc=s m#S18">Step
18</A> </P></TD>
Go to <A
<TR>
<TD vAlign=center align=middle><A name=S18>
18</P></A></TD>
With the scan tool, observe the stored information, capture info, and
DTC Info.</P>
Does the scan tool display any DTCs that you have not diagnosed?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30317&amp;RefDoc=828044&amp;evc =sm">Diagnostic
Trouble Code (DTC) List</A> in Engine Controls - 6.0L (LQ4)</P></TD>
System OK</P></TD></TR></TBODY></TABLE>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
Old 01-28-2006, 10:30 PM
holy info! Klaus is the man!
Old 01-28-2006, 10:40 PM
partsguy partsguy is offline
Oden of Hummer....You are the man!!!!
Old 01-28-2006, 11:03 PM
Klaus's Avatar
Just for grins, I'd check the "IGN 0" fuse.
Old 01-29-2006, 05:56 PM
TXSUT's Avatar
Thanks very much, Klaus...you are indeed THE MAN!
I checked the fuse, it's good. I'm still under warranty, so I'm not too concerned.
-Pete
Old 01-29-2006, 06:02 PM
is the dealer gonna fukk with you about the programmer you installled and changed the factory settings, does it have any affect on the warranty? iam wondring cuz i just put in the hyperteech and changed factory settings for my 37inch nittos
Old 01-29-2006, 07:57 PM
Christian GM Christian GM is offline
Christian GM is off the scale
Common problem, bad ignition switch.
Changed a lot for many DTCs on transmission and fixed ....
Easy and cheaper to do...
Old 01-30-2006, 11:04 AM
TXSUT's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MONSTERMATT:
is the dealer gonna fukk with you about the programmer you installled and changed the factory settings, does it have any affect on the warranty? iam wondring cuz i just put in the hyperteech and changed factory settings for my 37inch nittos </div></BLOCKQUOTE>
The dealer won't know, because I used the programmer last night to return the program back to the stock settings.
Old 01-30-2006, 11:06 AM
TXSUT's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Christian GM:
Easy and cheaper to do... </div></BLOCKQUOTE>
Thanks, appreciate that greatly. It's always good to be half-educated when dealing with the dealership, and I appreciate all the useful info here.
You guys are just great!
-Pete
Old 01-30-2006, 07:58 PM
TXSUT's Avatar
Dealership just called...bad ignition switch. WHEW!
Thanks again, guys, much appreciated!
Old 01-30-2006, 08:15 PM
some people just use their ignition switches too often
Old 01-31-2006, 12:32 PM
TXSUT's Avatar
some people just use their ignition switches too often </div></BLOCKQUOTE>
