Old 07-10-2005, 08:48 PM
First Hummer is off the scale
Has anybody noticed a little more wind noise after they have installed marker lights.
Old 07-11-2005, 12:36 PM
Hummertech is off the scale
You should expect some more wind noise. It's
something else to cause air turbulence.
However, look at how yours are installed, if there is a large gap between your light package and the body, then they did a crappy install, and I would take it back and tell them to fix it.
Old 07-11-2005, 01:33 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hummertech:
However, look at how yours are installed, if there is a large gap between your light package and the body, then they did a crappy install, and I would take it back and tell them to fix it. </div></BLOCKQUOTE>
Hummertech would you know if the radio harness is the same as the colorado.I want to go with an aftermarket radio but nobody has h3 wire harness.
Old 07-11-2005, 01:57 PM
Don't know for sure, but it probably is the same. Why do you want an aftermarket radio? I see so many problems caused from aftermarket radios, and I think the stock ones today do a damn good job.
Old 07-14-2005, 07:23 PM
Buddy in Az Buddy in Az is offline
Buddy in Az is off the scale
Does anyone know where to get the light bar that goes on just above the windshield?
Old 07-14-2005, 07:44 PM
DeLeon DeLeon is offline
DeLeon is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Buddy in Az:
Does anyone know where to get the light bar that goes on just above the windshield? </div></BLOCKQUOTE>
At the dealer or you can also go to http://www.h2parts.com
\'06 Boulder Gray H3 / Loaded
