Old 04-04-2006, 05:39 PM
Anthonykumpen Anthonykumpen is offline
Anthonykumpen is off the scale
Can somebody give me a suggestion how I can remove the headrest of my H2.
Are there any buttons?
It's a 2003 version
Old 04-04-2006, 06:06 PM
alldunn's chic's Avatar
alldunn's chic alldunn's chic is offline
alldunn's chic is an unknown quantity at this point
Just pull up on it....
Blumpkin,
You might want to try the FIND/SEARCH feature.
http://elcova.com/groupee/forums/a/tpc/f/5106011751/m/2...601034121#7601034121
Old 04-04-2006, 06:29 PM
Welcome to the forum!
Hey, this is a common problem so you'll probably get a lot of "use the search function" posts. Ignore them. It seems like a straighforward thing, but the fix for that problem is pretty unique.
Here's what most of us had to do to get them to come off:
First, remove the fuse box cover (driver's side near the door hinge). It works best to just use a screwdriver and pry it off.
Second,
Remove the fuse in the red circle. (see below). It should come right off.
Old 04-04-2006, 07:07 PM
Originally posted by Alec W:
What tools are required?
Sorry, my bad......
(1) Large screwdriver (prying off fuse box cover)
(2) Pliers - when you remove the fuse in the red circle, you bend it back and forth (up and down) a few times first. Then slowly work it out. Do NOT just yank it out. You need to loosen it up first to prevent arcing.
Old 04-04-2006, 07:19 PM
Sorry I know this is lame but I can't find the fuse box. I looked near the driver door and can only see windshield wipers. What am I missing here?
Use the search function, noob.
