Old 04-04-2005, 06:11 PM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
Anyone else having this issue multiple times?....this is the third time for me. They reset the code the first time saying GM had to have 2 instances before they would replace the unit. Now a third failure...they'll probably reset it again, and it will fail agian, when I'm in the middle of nowhere off-roading or a day after the warranty runs out.
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Hum2's Avatar
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 04-04-2005, 10:47 PM
LasVegas LasVegas is offline
LasVegas is off the scale
3 times is enough. Insist they replace it or determine/correct the problem.
Jonahs
Old 04-04-2005, 11:39 PM
tower's Avatar
tower tower is offline
"Could you say LEMON LAW? Sure you you could. I like the way you say that. Did you know that?"
-Fred Rogers, late kid's TV host
Old 04-05-2005, 10:14 AM
Hum2's Avatar
Ha! Insist on 100% service satisfaction from my dealer? I don't get it...it must be like one giant HMO...Let's see, if you break your leg, let's tape it up and see if it goes away on it's own, like before any Doctor's existed! If this thing fails when I'm in the middle of nowhere, I will be really torqued...I guess just at myself, because they will be too far away to hear me/care. I will have to hike out 10 miles to a town with no services. :-) I just don't get it, what shirt off their back is it to replace a part under warranty. I know,...I already have the latest part,...then why is it failing...again???
Oh well...they are trying! And, they have gone out of their way many times to fix things, but they should!!!
Lemon law...that's a "ha ha". Good luck! I know a gal that had the worst H2 in the world and it took over a year with lawyers to get GM to buy it back. My service folder is only an inch or so thick (2.5 years now)...sad but true
We'll, they just tweaked the computer again this time...and said "hope that works"! They saw no codes when they checked it the next day...Makes me wonder if they think I'm crying wolf! :-)
I had the new TB assembly put in at the second failure instance, so they didn't see any reason to replace it this time as I have the latest/newest part.
And, getting in to leave the drivers mirror failed to function properly...again...looks like I'm heading for mirror replacement #5! :-)
Don't get me wrong...I love my H2...just lamenting the loss of my 4-Runner that only had 1 piece of service paper in it's folder in 5 years. Dopey me, for getting rid of that vehicle!
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 04-06-2005, 01:00 PM
Exploding People Exploding People is offline
Exploding People is off the scale
sounds like another feature
Old 04-07-2005, 06:00 PM
Hum2's Avatar
Anyone know a simple way to reset the H2....I am aware of disconnecting the battery for a period...anyway to reset say the throttle body assembly without wiping out the radio/seats/shift memory, etc?
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 04-07-2005, 09:21 PM
partsguy partsguy is offline
I don"t know if Tech will agree w/me but All signals
go through the ing. switch.Maybe there is a comuacation
disrupsion between the PCM and the throttle body,which
may start with the ing switch.Maybe reaching but,Bad ground?
Old 04-08-2005, 12:05 PM
Hum2's Avatar
Thanks partsguy:
That may be the case here as after it set overnight, it started up fine for the dealer, and there were no system codes indicating a problem. That's a pretty stupid system if you ask me...there should have been an error code with the reduced engine power driving I went thru...again!
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
