11-16-2005, 01:03 PM
I see everything in the owner's manul for fluid change intervals, except the differential. What is the recommended fluid change interval?
Thx in advance!
Thx in advance!
11-16-2005, 01:43 PM
I dont take in consideration the user manual... I change all the fluid at 10000-15000 km. I think this is the best solution if you use on offroad... I (hummer italy) have make also an upgrade on transfer case (in Italian is radiatore) and some sticker that change colour.
11-16-2005, 03:16 PM
Thx in advance! </div></BLOCKQUOTE>Which one?
11-16-2005, 03:22 PM
The diffs...
11-16-2005, 03:25 PM
It's the same as the transfer case.
11-16-2005, 07:18 PM
I believe it is part of the 30K service, depending on your usage. More severe, more often.
11-17-2005, 11:00 PM
Phil:
Are you using Royal Purple in the transmission, transfer case, and differential? Also, can you tell us exactly what Royal Purple is (who makes it & what weight you use)?
Thanks,
George
