Old 03-15-2006, 02:28 PM
md_sailor's Avatar
md_sailor is off the scale
Sorry about your Mishap... No Bondo! The marine supply route is the easiest way to proceed. the correct way would be to Clean the rought damage out with a dremel and a burr bit. after that you would want to apply a mixture of Virgin Resin and Powdered fiberglass activated with MEK (methyl ethyl ketone) leave extra material on the repaired area so it can be sanded down to match the original shape. start with 220 wet dry sand paper and work progress through 600 wet/dry and you will end up with a smooth as glass surface. Paint/Gelcoat is your choice.... Hope this helps
