Old 01-10-2006, 05:21 AM
Shrek_H2 Shrek_H2 is offline
Shrek_H2 is off the scale
Okay guy/gals I really dont understand these tire sizes.....
I have a 2003 Hummer H2 that I picked up today...(Finally been waiting 3 weeks now for delivery and 3 years Ive wanted one...lol) anyways back to topic Im considering the following wheels and tires...
KMC Backseat Chrome 22X10
Toyo Open Country M/T 37x13.50R22
I know the wheels will fit but will the tires fit?...is 37 too much?...Also will these come out of the fenders cause if yes I rather go with 20"....
But if I go 20" can I fit
37x13.50R20
or
35x12.50R20
I want the big wheel 20 or 22 but i want the MT tires....please help
2003 Hummer H2
2000 BMW DINAN 5 (540i)
2002 HarleyDavidson V-Rod "FOR SALE"
All the great toys are on my driveway.....
37x13.50R20
or
35x12.50R20
2003 Hummer H2
Old 01-10-2006, 07:17 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
When I had my 20" Lexani's I had Les Schwab Tire throw on a set of 37/13.50-20 Toyo Open Country MT's. The rub was annoying enough for me to get 35/12.50-20 Nitto's. No rubbing at all.
I've read in this site that 37/12.50 tires will fit with little to no rubbing, depending on the tire. The biggest factor at that point will be the off set and backspacing of the wheel you choose. For example, my Lexani's were flush with the fenders while my Kaotic NT-2's stuck out almost two inches.
Also, if you go with 37's you'll end up having to get a programmer to address the slight loss in torque and speedometer issue. I've read several posts and asked many questions and this is the general concensus.
35/12.50-20 is the correct diamter for your truck. Also, please note that if you go with anything above 18 inches you'll feel the extra upsprung weight when you apply the brakes. That's why on our second Hummer we bought 35/12.50-18 tires and 18" wheels. But if you insist on 20" wheels, go with
35/12.50-20 or 325/60-20 tires. Both are correct for the H2. I highly recommend Toyo Open Country M/T's for their aggressive and quiet ride. Nitto Terra Grapplers are great as well.
Here's a pic of my old 18" combination with Toyo 35/12.50-18 tires. A Hummer needs meaty tires! Don't do the rubber bands!
2003 Yellow H2 LUX (Sold)
Old 01-10-2006, 07:19 AM
kacyk's Avatar
Here's what 325/60-20's look like on Lexani
Old 01-10-2006, 02:04 PM
Thanks for the reply now Im debating maybe 18"....hmmm
2003 Hummer H2
Old 01-10-2006, 05:24 PM
H222 H222 is offline
H222 is off the scale
37's on 22's
a little rub at full lock but nothing to cause any damage or annoy me that much-however my last three truck were 2 superdutys with 8" lift and 38's and a silverado with 35's and they all had minor tire rub too so you could say i'm probably used to it by now
03 Black Lux Package
22\" intimidators
37\" mudgrapplers
HID\'s
www.tintmasters.net
www.boozemob.com
www.solidperformanceinc.net
Old 01-10-2006, 07:22 PM
Boss Hoss's Avatar
Boss Hoss is off the scale
Unless you are going to be doing some SERIOUS wheeling which would require you to air down substantially i think you would be best off with a 20in. With a 20in youd still have a big rim look with plenty of sidewall to protect your rim. One thing to conseder also would be a 35x13.50-20 tire. This tire would be 1" wider and IMO it gives a better stance than a 12.50. This is just my opinion and you know what they say about opinions. BTW, can you guess what im running on mine?
Old 01-12-2006, 04:18 AM
Can you please tell me what size rims and tires you are running Boss Hoss? I guess 35x13.50x20....but are the wheels 20x9?
Damnit those TOYO M/T dont come in 35x13.50x20 only 35x12.50x20....
Boss Hoss ....what aare yours i like the setup?
2003 Hummer H2
Old 01-12-2006, 12:44 PM
Alex13188 Alex13188 is offline
Alex13188 is off the scale
ill guess: 20in Kaotik NT-1s with 35x13.50Pro Comp Xtreme All terrain
Old 01-12-2006, 02:05 PM
Is their a big difference between 35x12.50x20 and 35x13.50x20?
2003 Hummer H2
Old 01-12-2006, 02:50 PM
Boss Hoss's Avatar
Shrek, from what i know even though the Toyos dont come in a 13.50 i would think it would be a better tire for wheeling(and it looks awesome too). There are two reasons why my tires are wide...obvisously because the 13.50 is wider than what you are used to seeing in a 35in(12.50) but second is because im running a 10wide rim. I may be wrong but i think a wider rim will give your tire a wider look. You can buy 20's with a 8.5in or 9in wide rim, but it doesnt give the same look as a 10 or 11in wide rim IMO. MKW makes a rim very similar(m19) to mine but instead of being a 20x10 it is a 20x11. I think the Toyos would look sweet on either rim just dont go with a rim less than 10in wide. Mickey Thompson also carries tires in a 35x13.50-20.
Old 01-12-2006, 06:44 PM
TXSUT's Avatar
TXSUT TXSUT is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Shrek_H2:
Is their a big difference between 35x12.50x20 and 35x13.50x20? </div></BLOCKQUOTE>
About an inch.
Sorry, but someone had to.
Old 01-12-2006, 09:58 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TXSUT:
About an inch.
Sorry, but someone had to. </div></BLOCKQUOTE>
Thanks but I rather see pictures if anybody has?
2003 Hummer H2
Old 01-12-2006, 09:59 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Boss Hoss:
Shrek, from what i know even though the Toyos dont come in a 13.50 i would think it would be a better tire for wheeling(and it looks awesome too). There are two reasons why my tires are wide...obvisously because the 13.50 is wider than what you are used to seeing in a 35in(12.50) but second is because im running a 10wide rim. I may be wrong but i think a wider rim will give your tire a wider look. You can buy 20's with a 8.5in or 9in wide rim, but it doesnt give the same look as a 10 or 11in wide rim IMO. MKW makes a rim very similar(m19) to mine but instead of being a 20x10 it is a 20x11. I think the Toyos would look sweet on either rim just dont go with a rim less than 10in wide. Mickey Thompson also carries tires in a 35x13.50-20. </div></BLOCKQUOTE>
thanks for the info ...I went with the KMC Backseat 20X9 Black.....tires I might go with the 37x13.50.20....will that rub?
2003 Hummer H2
