Old 08-01-2005, 04:11 PM
MBuhrig MBuhrig is offline
MBuhrig is off the scale
Hi All,
My sister was nice enough to buy me a $350 detail package for my '97 NA 2 door ExtCab H1 as a very late birthday present.
Against my best judgment it took it in. They did a great job inside and out other than the fact that my Glow plug light went on and did not go back out until the controller burned up the first time I started it.
I have the truck at the dealership now because I could not find the short. Any ideas? They have been going back and forth with Indiana for a week now with no luck.
Has anyone experienced this before? I am assuming it was the detailer pressure washing where he should not have been pressure washing but it could also be dumb luck.
Any help would be appreciated.
Marc
Hi All,
Marc
Old 08-03-2005, 08:09 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
I would take apart the main engine wiring harness connector and check for water intrusion. That is the one right in front of the driver window. Then I would check the connector at the controller to the rear of the passenger side valve cover for the same water intrusion. It sounds like that is what happened.
Make sure you use dielectric grease when you reseat the connectors.
Dave
