Old 08-27-2005, 12:11 AM
JHALL JHALL is offline
JHALL is off the scale
im not sure what the problem is but my drl's and my front bar lamps wont work.....there is a under hood 30 amp fuse that blows as soon as i put it in and cut the front bar lights on??...it is in the "stud #2" position ...can anybody tell me what that stud #2 runs?...any help on this matter would be much appriciated...thanks
Old 08-27-2005, 12:42 AM
VTSTOMPER is off the scale
Are you talking a stud in the fuse box, or on the switch?
check this http://www.elcova.com/h2/details.html
and open the manual to section 5 - scroll and you will find all the fuses and what they do.
To me it sounds like a pos and neg are touching...like maybe in the guard lights. Either way the fuse blows because there is a problem. You can check the wires for voltage with a volt meter too...just some ideas, you may have already tried them. You didn't tap into your DRL power lead did you?
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 08-27-2005, 12:52 AM
in the under hood fuse box under the lid when you look at the diagram of the fuses the one that keeps blowing is listed as "stud #2"...or thats what it says on the diagram ???...im just not sure what all that runs?
Old 08-27-2005, 01:02 AM
STUD #2
Accessory Power/Trailer
Wiring Brake Feed
