Old 10-02-2003, 03:24 PM
ANGELO D. ANGELO D. is offline
ANGELO D. is off the scale
I have rancho 4in lift and can only see couple of car lengths behind me when I am driving down
highway. I have airbags in back, and was wondering can they be adjusted at the dealer to ride higher inorder to get the rear end up so I can see more than 1/car length behind my vehicle. IS there anyone else out there with rancho 4in lift with airbag rearend with same problem. would like to hear your comments.
thanks.
thanks.
Old 10-02-2003, 04:08 PM
DURAMAX TIM is off the scale
U have 2 leveling valves on the rearend (behind tire).
U can adjust these to give u the ride height u want.
I haven't looked close but if u make plates or redrill 2 holes u could move the arms so it thinks it is low and will pump up the bags some.
U could also back off the torsion bars on the front end to let it down some.
The front end will settle some after the lift when everything gets seated in.
98 ZR-2 Blazer
Ex H2&3 owner
Old 10-02-2003, 04:23 PM
HummerTeam HummerTeam is offline
H2 Club DFW Chapter Founder
HummerTeam is off the scale
I have the 4" lift, and have not noticed what cars I can see behind me. I mostly use my side mirrors. It dosent make much sense to me to lower something you have already raised?
Get a rear facing camera if you are really concerned about your rear view. Do a search for rear-view cameras on this forum, it has been discussed at length.
Travis
http://www.HummerTeam.com
Old 10-03-2003, 08:45 AM
Circuitguy
Travis is giving you very good advice, get a Hitch-Cam. If you want to see one go to the front page of my site. You will find a pic of it there. BIG-C
White 03-H2-LUX
</a>
