Old 05-22-2006, 09:51 PM
zeros zeros is offline
zeros is off the scale
Default gps antenna removal?
hi i was wondering if anyone had a diagram on how to remove the gps antenna .. i see were it is..in the dash close to the light sensor.. i just wasnt sure how to get in their and get it... .. thanks
Old 05-24-2006, 02:48 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: gps antenna removal?
Global Positioning System (GPS) Antenna Replacement
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1412750&psdid=890&evc=sm#ss1-1412750">Removal Procedure
  1. <LI type=1>Remove the instrument panel (I/P) top pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper in Instrument Panel, Gages, and Console. <LI type=1>Remove the radio. Refer to Radio Replacement in Entertainment. Important: Observe the routing of the global positioning system (GPS) antenna cable to ensure the GPS antenna cable is routed properly during installation.
    <LI type=1>Remove the GPS cable from the I/P structure. <LI type=1>Remove the GPS antenna screw (1). <LI type=1>Slide the GPS antenna (2) toward the passenger side of vehicle to remove the antenna from the I/P structure.
  2. Remove the GPS antenna (2) from the vehicle.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1412750&psdid=890&evc=sm#ss2-1412750">Installation Procedure
  1. <LI type=1>Install the GPS antenna (2) to the I/P bracket. <LI type=1>Route the GPS antenna cable to the radio opening, as noted in the removal procedure. <LI type=1>Slide the GPS antenna (2) toward the driver side of vehicle and align the screw hole. Notice: Refer to Fastener Notice in Cautions and Notices.
    <LI type=1>Install the screw (1). Tighten
    Tighten the screw (1) to 2 N?m (18 lb in).
    <LI type=1>Install the radio. Refer to Radio Replacement in Entertainment.
  2. Install the I/P top pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper in Instrument Panel, Gages, and Console.
Old 05-24-2006, 03:52 PM
hi im not sure how to get the dash apart above the glove compartment. i took the 4 metal long screws out but it didnt seem to do anything.. i see where the gps antenna is im just not sure how to remove the dash above it ... any ideas... thanks
