Old 05-26-2006, 12:32 PM
Default Re: service@25,000
Originally Posted by PhilD
Nothing. Service intervals are at 22,500 and 30,000.
Apart from an oil change and lube, this is what your manual says;
22,500 Miles (37 500 km)
Check rear/front axle fluid level and add fluid as needed.
Check constant velocity joints and axle seals for leaking.
Rotate tires.
30,000 Miles (50 000 km)
Rotate tires.
Replace fuel filter.
Replace engine air cleaner filter.
Inline fuel filter is only on the 2003 H2 with the returnless fuel system. 2004 and newer have the filter in the tank and it is non-serviceable.
