05-26-2006, 03:56 AM
Bent under carriage protection
My stock ucp is pushed up into the exhaust cross over pipe. Looks it is bent in other places but not against anything.
Has any one pulled it down with a floor jack, chains and blocks against the frame?
I certainly can not be the first owner to have this pushed up.
Any suggestions from someone who has fixed it would certainly help,
Thanks,
Gary
05-26-2006, 04:41 AM
Re: Bent under carriage protection
I have failed to reason why I needed to make any adjustments to mine. It seems to be bent up in their just fine and all I'll do is get agitated if I try to straighten it out adn get the bolt holes to align again.
Besides it finally doesn't rattle or anything.
05-26-2006, 04:57 AM
Just get longer bolts and a $h1t load of washers.
05-26-2006, 12:46 PM
[quote=PhilD]Like this;
[IMG]http://www.*******club.com/temp/cage.jpg[/IMG]No problems with bolt hole alignment after the drive on?]
05-26-2006, 02:56 PM
Thanks,
Gary
No sense in trying to straighten it now you are only going to beat it back up next week in the Black Hills.
05-26-2006, 03:19 PM
That standard trick to fix it from rattling is to put a stack of washers on each of the three bolts in the rear.
However, that stock protection is worthless.
Call H20guy at get this. Impossible to bend.
05-26-2006, 09:03 PM
That really is a nice UCP. Too bad you lose that inch of clearance... but that's a good reason to get 37's.
05-27-2006, 01:30 AM
Originally Posted by PhilD
It's called ground effect, helps the vehicle stick to the ground down the straights
H2O make great stuff though, very well thought out and made.
How do I reach H20 or a website?
Thanks,
Gary
05-27-2006, 01:42 AM
