Old 06-07-2006, 11:43 PM
cmd's Avatar
cmd cmd is offline
cmd is on a distinguished road
Default Door handle question
Has anyone changed the door handle buckets, how do you remove the handles from the old set of buckets?
Old 06-18-2006, 06:36 AM
sniknuh sniknuh is offline
sniknuh is off the scale
Default Re: Door handle question
Taking off the door buckets will require about 30 minutes to 1 hour per door. Once you remove the buckets, you can easily remove the handles.
Old 06-18-2006, 05:14 PM
MDimitri's Avatar
MDimitri MDimitri is offline
Arrow Re: Door handle question
It's a big pain in the "you know what!!" It's probably one of the most frustrating things you can do on your H2.
Old 06-19-2006, 04:02 AM
vip808 vip808 is offline
vip808 is off the scale
i hope this helps
Old 06-21-2006, 12:54 AM
cmd's Avatar
cmd cmd is offline
Thanks Vip808, worked out great, the handles were tight and would not return to the closed position when released, perfect now.
Old 06-21-2006, 07:41 AM
cmd,
that's great.. i tried to get the info to you earlier but it was in a .pdf file that was too big to post.. i put it on my web host but it was taking space away so i had to delete it.. glad it turned out
