07-04-2006, 10:07 PM
Re: AVIC-Z1 INSTALLED!!
When I installed this system, I removed the AUX input and the HK Drive + Play iPod adapter. I am going to be selling these 2. If anyone is interested let me know or else I will just put them on eBay.
2006 H3 Black Luxury package; Off-Road package; Sunroof; AVIC-Z1/Monsoon; XMNavTraffic; iPod adapter; Rear view camera; Front bumper letters; Splash guards; Mudder floor mats; UC Protection
07-05-2006, 07:38 AM
Why didnt you just use the factory XM antenna? It worked in mine.
08 H3 ALPHA Carbon Black
Dear GM: PLEASE SELL ME AN HX
07-05-2006, 04:03 PM
I tried to, but the little notches on the inside of the connector did not match up with the ones on the GEX-P10XMT. It was easier to just run the new XM antenna then to hack around on the connector.
07-07-2006, 01:06 PM
ahhh.. yea.. you pull that connector cover off and it slips right in there.. i got the same setup
Grats on the installl... I've been very happy with the unit. And god bless the bypass.. saved my sanity playing a DVD for the g/f on a long road trip. (kept her busy... I of course never looked)
07-08-2006, 02:21 AM
Hey guys.
My 3d hybrid mode does not work, and the sensor shows no speed pulse, however on the vehicle dynamics of the z1 it does record my vehicle speed.
First off what does 3d hybrid do anyway?
And my installer assured me the vss was hooked up.
I am kind of doubting that at this point, since these features should work.
Where is the vss wire located and what color is it?
Thank, in advance, for your help.
07-08-2006, 02:54 AM
Originally Posted by nafs
Hey guys.
My 3d hybrid mode does not work, and the sensor shows no speed pulse, however on the vehicle dynamics of the z1 it does record my vehicle speed.....
...And my installer assured me the vss was hooked up.
I am kind of doubting that at this point, since these features should work....
Sorry, can't help on the questions but can tell you that I did not hook up my VSS but on the vehicle dynamics on my D1 is shows the correct speed. It doesn't need the VSS hooked up to do this because it is using the GPS coordinates to determine your speed. I am betting you are right and your installer is lying to you
07-08-2006, 05:25 AM
I would agree. The speed pulse wire is not connected correctly.
07-08-2006, 05:54 AM
Where did you guys find the vss wire and what color is it?
Thx for the responses.
07-12-2006, 06:00 PM
Hi,
With the Z1 install and the factory Monsoon do you have to rewire directly to the speakers or do the adapters take care of the amp bypass? I still want to use factory sub. Do you have a good route for the Pioneer rear camera install?
H3 slate blue, lux package, off road package, sunroof, chrome
07-12-2006, 08:18 PM
Originally Posted by bigdog100
Hi,
I had the Monsoon system in my truck and installed the D1. Adapter takes care of all the wiring but eventually I will run new wires to the speakers.
07-12-2006, 08:25 PM
Why would you need to rewire if it works? Does the sub still work?
07-12-2006, 08:36 PM
Sub still works great. It was recommended by kodiakz. He has don't a number of installs with the Monsoon system and has found the aftermarket heads sound a lot better after running new wiring to the speakers. My sounds great as is so it is just a matter of when I get around to doing it.
