Old 07-08-2006, 11:38 AM
smh3 smh3 is offline
smh3 is off the scale
Default tire monitoring system
question to the experts here. took my h3 into the dealer because the check engine light came on. The said there was a loose cable by the fuse box. the kicker is they said they also reprogrammed the system?. my tire monitoring system know always show low tires, they are at 35 lbs actually too high. I had the system adjusted months ago and it worked fine. I think is was adjusted to 27lbs before it came on. now they say they cant go below 29lbs. i know the tires or even higher that 29. what have they done to mess it up and why cant they return it to the way it was before i took it in or am i being feed a line of crap.
Old 07-08-2006, 02:37 PM
2xtreme's Avatar
2xtreme 2xtreme is offline
2xtreme is off the scale
Default Re: tire monitoring system
Maby try resetting the monitors on each tire. There is a description how to do this in your owners manual. The only thing I can think of happened is when they reprogrammed the computer it reset the TPM.
Old 07-08-2006, 08:22 PM
Which tires do you have? The recommended PSI on the Bridgestones is 35 and my sensors go off at around 30. Sounds like you just have the pressure too low.
Old 07-09-2006, 10:31 AM
thanks for the ideas. the tires are at 35 and the senors still going off. until they reset the tpm monitoring system I had no issues. they said they lowered to 29 but still shows low. any way to disable the system
