Old 08-10-2006, 11:49 PM
vador99 vador99 is offline
vador99 is off the scale
Default any h2 with strobe?
i am searching for pic from an h2 with strobe light installed.
thanks... merci( i surrender)
Old 08-10-2006, 11:54 PM
Beastmaster's Avatar
Beastmaster is off the scale
Default Re: any h2 with strobe?
Why?
M101A2 Trailer
Old 08-11-2006, 12:00 AM
Originally Posted by Beastmaster
Why?
Why? Where? What kind?
Old 08-11-2006, 12:09 AM
Why?
NO, SERIOUSLY...WHY????
Old 08-11-2006, 12:18 AM
1Sonterra's Avatar
1Sonterra 1Sonterra is offline
1Sonterra is on a distinguished road
How about the ones on CSI Miami? Do their law enforcement H2s have the police strobe kits?
Old 08-11-2006, 02:19 AM
No, but my H1 does..
M101A2 Trailer
Old 08-11-2006, 02:24 AM
i need it because i want to install one on my h2.Need it for my work!
want to install maybe behind grill or over the bumper
Old 08-11-2006, 02:51 AM
xonxoff xonxoff is offline
xonxoff is off the scale
I put two strobes in my front two piaa's two in outside roof mounted piaa's and in the back up lights.
I use them for an emergency response team.
Black 04 H2
Old 08-11-2006, 04:03 AM
Sweet! How about some pics?
Old 08-11-2006, 04:11 AM
Ok - next question...
LED or Xenon?
LED - lower power draw
Xenon - wider variety of mounting options
M101A2 Trailer
Old 08-11-2006, 04:14 AM
maybe a 4 light(led dominator type) here will be okay.
Old 08-11-2006, 04:41 AM
Depends. Brightness isn't an issue. The bad thing about LED lamps is the lack of good angled visibility.
That's my primary problem with my Able2 Sho-Me LED Strobes. In order to get good coverage, you really need at least one strobe on each side plus front and back.
When I repaint my rig, I will end up adding a single white LED cluster to each side of the rack to aid in visibility.
With my current LED strobe setup, I get excellent front/rear coverage. So much so that I get about 1/2 mile daylight coverage and at least 1 mile at night. Able2 says I'm supposed to get 1/4 mile daylight coverage, and with the lights improperly aimed, that would be the case.
Which brings up the issue with the Dominator - if you're going to use it, put it up higher. The placement you're looking to use is good for secondary lighting, but if you're wanting it to be the primary warning setup, it's gotta be higher up.
Here's an example of what I've done to my rig. The cool part of the Able2 stuff - it's so low profile that it's able to literally blend in with the roof rack and it still gives good to excellent primary warning. The Dominator sticks out a bit more, and I'd hate to break a TIR3 light cluster where you want to place it. Those TIR3 units are expensive.
http://www.azhog.org/sho-me_LED_stro...ED_strobes.htm
Movies are available to show an example of daylight use along with other various shots.
-Steve
M101A2 Trailer
