08-30-2006, 03:25 PM
Re: Transmission fluid?
Should at least run cooler, but I would like to see it for myself (as I have done on the syn motor oil).
09-04-2006, 07:08 AM
Hey guys, my '06 says to use the new D-IV on the dipstick & in the manual. If their flush system is hooked up to a bulk container of D-III, I am wondering how this is going to work out. Input appreciated...
09-04-2006, 01:58 PM
I will guess, that most GOOD dealers will use only DVI in the future. DIII will eventually runout via GM service parts, if not already gone. DVI can be used on all older GM vehicles, except for Saturn S-Series, VUE V6, CVT transaxles, and not sure about SAAB.
09-11-2006, 10:10 PM
I would suggest a complete flush if the oil is burnt. I suspect your tranny may be running on the high side at some periods.
If you can spare the coin, try the PML tranny pan for added cooling due to it being aluminum and holding more fluid. www.trailduty.com has them in stock.
Since your '03 requires DIII ATF you could also try Syn ATF, or just upgrade to the new GM D6 (Dexron VI) ATF.
Originally Posted by cmd
looking for input on recommended tranny fluid to use, and if the filter is only available from gm or are there optional filters available on the market that are recommended. I understand that some members have noticed a differance in the performance of the transmission once performing the service. I have 45k on my 2003 h2, I checked the fluid and i believe it smells a bit on the burnt side.
06-30-2007, 12:08 AM
Originally Posted by PhilD
There is a shadetree way that you can do it yourself. Disconnect the out tranny cooler line and connect some rubber hose to it, route the hose to a large graduated container. Run the engine and add ATF at the same rate you are pumping it out. If you can't add it fast enough have someone sat in the cab to cut and start the engine as required. Kind of basic, but it will work.
I want to flush my transmission and was wondering if a fluid extractor (like a MityVac) would remove all of the old fluid? Connects to the dipstick? Maybe?
One like this? http://www.mityvac.com/pages/products_fee.asp
