Old 08-30-2006, 08:03 PM
Lean Machine's Avatar
Lean Machine Lean Machine is offline
Lean Machine is off the scale
Default Re: Battery died....
My battery died on me last week and left me stranded in a parking garage downtown. I called 1-866 Hummer 6 for roadside and my battery was replaced under warranty. Do I need to have the dealership run more diagnostic test to determine why the battery died in the first place or just accept the fact the batteries are a POS and move on.
\'05 H2 Lux Pewter SUV, Nav, Air, Sunroof, 22x10 E Forged EF16 with BFG Limited Edition Mud-Terrain T/A 335/55R22 and varies Chrome Parts
\'08 H2 Lux White SUT with Sedona interior - SOLD
\'08 H2 Lux White SUT with Sedona interior and 6'' Fabtech Lift
Old 08-30-2006, 08:15 PM
CONRAD II's Avatar
Originally Posted by obzidian
i have a red in my camaro and i will also swear that i picked up another 10rwhp with the swap!!!!!!
66' VETTE STINGRAY
07' Z06
Old 08-30-2006, 08:17 PM
CONRAD II's Avatar
In that case you should try changing the air filter also. By one from K&N and you can expect at least another 40 or 50 rwhp!
66' VETTE STINGRAY
07' Z06
Old 08-30-2006, 08:28 PM
ASTAR's Avatar
ASTAR ASTAR is offline
ASTAR is on a distinguished road
Go with a red top.
MINE - 2006 H2 SUT
Old 08-30-2006, 10:37 PM
obzidian's Avatar
obzidian obzidian is offline
obzidian is on a distinguished road
well, roadside service came by and they replaced the battery. It held a bit of volts, 8 or so, but the battey was not hold at all...
so we replaced it and it cranked up fine... we'll see where we at in the future with this battery stuff.
Origanally, i traded my 05 cts-v and that had cronic battery problems... oh well, this one should hold be i will monitor it...
laterZ!
Old 08-30-2006, 11:23 PM
laterZ!
in the future could you please hire a translator to do the typing for you
Thank you for your understanding.
Have a nice day!
Old 09-04-2006, 12:01 AM
You are joking... If not BS
Old 09-04-2006, 05:48 PM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Hey,
What are the difference between Red and Yellow Top....
Old 09-04-2006, 06:07 PM
Deep cycle (yellow top) is designed to be discharged repeatedly with no damage to the battery. They will be heavier due to the increased size of the lead used in the plates.
A deep cycle battery is designed for vehicles with a lot of accessories that will cause drain such as winches, large stereos, tons of off-road lighting, etc. Deep cycle batteries the same size as a regular battery do not have as high of CCA. Therefore, it is suggested to go to a larger deep cycle battery.
The yellow top Optima D75/25 has 650 CCA, while the 75/25 red top has 720 CCA. If you are in a cold climate, the CCA can be important. In addition, cranking amps at 32 degrees F is 100 amps more for the red top versus the yellow top.
Old 09-05-2006, 06:03 AM
dochummer's Avatar
Battery went completely dead again while camping.... probably time to purchase a yellowtop....
'03 H2
