Old 03-25-2006, 10:09 PM
cognitive cognitive is offline
cognitive is off the scale
H2 won't start. may have run out of gas. have gas now and battery but no start. what to do?
someone said solenoid flakey so try rapid key start. doesn't work.
another said alarm is preventing it from starting.
another said fuel pump is fried.
is there anyth8ng to try b4 towing?
Old 03-25-2006, 10:37 PM
how? thanks for help
Old 03-25-2006, 10:46 PM
tried unscrewing negative from batt, waitee a few minutes +put back. still no luck. could it be fuses?
Old 03-25-2006, 11:09 PM
fuses look fine. i don't hear the starter click. frustrating.
Old 03-25-2006, 11:15 PM
intimidator intimidator is offline
intimidator is off the scale
ok does it crank but not start or
no crank no start?
Old 03-25-2006, 11:30 PM
Kevin B Kevin B is offline
Kevin B is off the scale
sounds like no crank .
If so I would clean battery terminals for starters (no pun intended).
Old 03-25-2006, 11:31 PM
MovinH2's Avatar
MovinH2 MovinH2 is offline
MovinH2 is off the scale
Originally posted by Kevin B:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">i don't hear the starter click. frustrating.
If so I would clean battery terminals for starters (no pun intended). </div></BLOCKQUOTE>
X2.
Old 03-26-2006, 03:16 AM
CampMaster CampMaster is offline
CampMaster is off the scale
could be a clogged fuel filter.
If the gas got too low dirt/particals at the bottom of the tank could have been sucked up the line and blocked the fuel filter.
Old 03-26-2006, 03:37 AM
Holy first grade writing.
Running out of fuel with a FI engine is a no-no. My first thought is to the fuel pump. It needs the fuel for lubrication.
Old 03-26-2006, 10:04 AM
I'm guessing it was the fuel pump too. I'll find out this week. It does not crank but everything else appears to be fine. As for the first grade writing... kenp... I lost power on the George Washington bridge and luckily coasted off an exit - in a straight line b/c the power steering turned off. I was typing on a tablet in the car while waiting for tow trucks from AAA. I just wanted to get out of there. I don't care what type of engine this is. If running out of gas isn't cured by adding more gas only, then the design is severely flawed. I knew about this before but the last gas station I passed was under construction. I didn't think I was totally out but maybe the fuel pump had been damaged prior to yesterday and finally gave out. If it is the pump, what am I looking at in terms of repair cost and time?
Thanks everyone for your suggestions.
Old 03-26-2006, 10:18 AM
tomp's Avatar
tomp tomp is offline
My Guess: Bad alternator and you ran off battery power until it then died. Now it won't start because you sucked all remaining life out of battery. You may need to charge or replace battery and R&R alternator.
Old 03-26-2006, 10:26 AM
Actually, since there isn't a crank, it might be a terrible coincidence between losing fuel and the ignition switch/fuse. If I recall correctly, the ign1 is a block, not a simple fuse. Is that the switch + fuse or just a fuse and the switch is elsewhere?
Old 03-26-2006, 01:12 PM
You sent it off w/o even charging up the battery or cleaning the battery terminals .
Old 03-27-2006, 11:39 AM
No, I had the battery charged and everything seems to be powered (windows came on last I think). Still no crank. I'll find out today.
Old 03-27-2006, 12:00 PM
Klaus's Avatar
Klaus Klaus is offline
Probably the transmission interlock wiring at the shifter. When the wire breaks inside from flexing, the vehicle thinks it is in gear and will not start.
Old 03-29-2006, 11:22 PM
Turned out to be the PCMB fuse under the hood. Why it blew is anyone's guess. At least now I know where to check if it happens again.
Old 03-30-2006, 01:10 AM
HummMe
The PCMB fuse is the power supply to your fuel pump relay-Chances are you overheated the fuel pump by trying to start it over and over w/ no fuel. You definately took some life off that pump.
