Old 09-09-2006, 10:04 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: Do they make a snorkel for H3?
Originally Posted by reddevil
Hello,
Just wanted to ask if u guys knew if they make a snorkel for the H3. Also, Whats the biggest size u can put on an H3 without any rubbing anywhere?
Even if you put the air intake higher, the rest of the electronics would still limit the H3's max fording depth...only the H1s have kits that you can 'waterproof' the necessary parts and extend the air intake -- they even have special brake lines that will still work with the pressure from being under a few feet of water...H3s and H2s do not have those systems....yet...
-Brian
http://www.hummerguy.net
