Old 09-09-2006, 03:13 AM
Dirtdog74H1 Dirtdog74H1 is offline
Dirtdog74H1 is on a distinguished road
Default Question Guys
Want to put these KMC Rockstars on my H3. Can anyone tell me if they will fit. They are a private sale. The size are 18x9 six lug. The guy told me the distance between lugs opposite each other on the rockstars are 5 1/2 inches which is identical to the H3. He also told me the opening in the middle is approx 4 1/4 inches. It appears that the opening on my truck is 4 inches.
Can anyone offer any light on this issue. I don't want to buy unless i'm sure they will fit. Can'ts seem to make contact with KMC directly. My guess is that they will fit. Thanks for your thoughts guys.
Old 09-09-2006, 06:26 AM
Default Re: Question Guys
Better check the backspacing since they're 1.5" wider than stock.
Old 09-09-2006, 01:27 PM
Okay, what would I need to do to get them to fit. Could I purchase something to make them fit?
As you can see, i'm knowledgable with this stuff.
Old 09-11-2006, 05:23 AM
MountainBlue MountainBlue is offline
MountainBlue is on a distinguished road
It depends on the size of tire you want to run will determine how much backspacing you will need to keep the rim/tire from rubbing. I'm haven't even looked at the stock rims to see what the stock backspacing is, but if the rims are 1.5" wider than stock, the backspaing should be less than stock on the new rims, by .5-1" depending on tire size. The wider the tire, the less backspacing you want. That is, if my tire memory serves me right.
Slate Blue 06 H3 Auto, Lux, Chrome, Navi, Sunroof, Chrome side steps, Home Link, Trailer, & Rig lights
Volant intake, Airaid TB spacer, Custom down pipe, Magnaflow dual Exhaust, NGK iridium plugs, Nitto TG -AT295/75/16, Brush guard, tail light guards, mud guards, Chrome Shorty Antenna & bracket, Chrome lower punch grill & lettering, Chrome side moldings, smoked side marker lenses, 3-D Hummer hitch plug, Body color spare cover, & of course DEBADGED!
Old 09-12-2006, 04:27 AM
Makes sense blue. Want to put the following size tire on these wheels 325/60/R18. I'll look into the backspacing issue.
Old 09-12-2006, 05:38 AM
I hope you are adding a lift kit to your list, no way 325's will work without a lift.
Old 09-12-2006, 07:07 AM
That's the size tire Truxxx uses and I would think you need their kit to run them. And they would still need to stick out quite a bit. That's a lot of rubber for the H3.
