Old 09-30-2006, 02:06 AM
tomp's Avatar
tomp tomp is offline
Default New Warn Detach Winch w/built-in Air Compressor?
http://www.quadratec.com/products/92101_100_07.htm
Sweet!!!!
Old 09-30-2006, 02:11 AM
Default Re: New Warn Detach Winch w/built-in Air Compressor?
That is pretty cool.
INFO:
Fits these Vehicles
  • Universal Fit - This part will fit most vehicles. Some universal fit products require that you select a specific size or style, based on the actual features on your truck.
Parts Included
  • Winch
  • Air Hose and Fittings
  • 125 feet of 5/16" Wire Rope
Product Details
Switch to winch mode and the PowerPlant turns on the legendary WARN winch technology. You get the raw pulling power of a Gen II Series Wound motor. Plus the proven reliability of the 3-stage planetary gear train. In other words, WARN to the rescue, time after time. The PowerPlant Dual Force comes with air hose and fittings. Additional air compressor accessories are available (such as larger air tank needed for some power tools).
9,500 lbs. maximum rated pull (single line)
Fast line speed of 26.9 feet per minute (no load), 5.2 feet per minute (at 9,500 lbs. max load)
125 feet of 5/16? wire rope
tomp's Avatar
The PowerPlant is available in two configurations: HP for off-road vehicles for enthusiasts who demand faster line speed, and HD for heavier trucks for longer motor duty cycles.
NOTICE the HD model is 12K#s!
Old 09-30-2006, 02:13 AM
tomp's Avatar
http://www.warn.com/powerplant_accessories.shtml
Check out the air tanks! I can see PhilD mounting one of these tanks back there where the OEM air compressor was intended to go, since he doesn't have the onbaord air!
Old 09-30-2006, 02:16 AM
tomp's Avatar
I am going to eventually have to give this a try. Mount quick-disconnect air fittings in bumpers and air tank where OEM compressor goes.
Old 09-30-2006, 02:42 AM
That is pretty sweet.
Old 10-01-2006, 01:27 AM
Originally Posted by PhilD
I'm actually pretty practical when it comes to my truck and tend to only do stuff that is needed. If I can get away with using what I have, I'll generally go that route. There's only so many times the wife will believe the, "It was broken so I needed to replace it anyway" line
No kidding, Phil. Just be thankful she doesn't go with you on the trails because then you'd never be able to get ANYTHING without checking with her first.
Me=
Old 10-01-2006, 03:17 AM
Very interesting.
