Old 03-29-2004, 06:22 PM
JamesT's Avatar
JamesT JamesT is offline
Does anyone have a back up camera installed? If so, how dificult was the install? Thanks!
People Who Annoy Me...NAGGERS
JamesT's Avatar
JamesT's Avatar
Old 03-29-2004, 06:48 PM
KIDZBOX KIDZBOX is offline
KIDZBOX is off the scale
I'm curious too. I have the factory GPS and would like to use the existing screen. Anyone know if it's possible?
I've seen a backup option on the after market Pioneer and others but when the screen's up it blocks the two air vents in the center.
Old 03-29-2004, 08:26 PM
Jigga Jigga is offline
Jigga is off the scale
Hey James, I did a brief description w/ some pics of a custom camera mount I did on my H2. I'll attach a link to the thread (hope it works) and maybe it could give you some ideas.
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=5106011751&m=814607753 5&r=9906078635#9906078635
Sig lines are overrated.
Old 03-29-2004, 08:31 PM
JamesT's Avatar
Thanks Jigga...
Old 03-30-2004, 02:48 PM
max max is offline
max is off the scale
I have installed a video monitor above the rear view mirror and did it without drilling any holes. I made a template out of cardboard and made the bracket to match out of thin guage stainless and powder coated it. The bracket fits under the sunroof trim and clips behind the upper consul housing. The wiring ran without any holes and the power supply was fused and wired into the back-up lights. It powers up only in reverse and the micro camera is mounted in a 1"x1" custom housing attached to the top, inside,center of the rear window. Invisible from the outside and wide lens eliminates the low blind spot. I hope these pics tell the story.
Old 03-30-2004, 02:52 PM
max max is offline
Pics sent one at a time. Let me know if these 2 help.
Old 03-30-2004, 02:53 PM
max max is offline
Monitor pic.
Old 03-30-2004, 02:57 PM
max max is offline
Hope this pic opens.
Old 03-30-2004, 03:00 PM
max max is offline
I'm having trouble sending the pics. They are saved as JPG at 514 KB. Help...
Old 03-30-2004, 03:06 PM
JamesT's Avatar
MAX...please email the pics to me at james@fixmyprinter.com
Old 03-30-2004, 03:44 PM
JamesT's Avatar
He is the PICs!
Old 03-30-2004, 03:45 PM
JamesT's Avatar
One more
Old 03-30-2004, 09:01 PM
H2Finally's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by max:
the micro camera is mounted in a 1"x1" custom housing attached to the top, inside,center of the rear window. Invisible from the outside and wide lens eliminates the low blind spot. I hope these pics tell the story. <HR></BLOCKQUOTE>max, can you show pic of the camera, as well as the IMAGE of what the camera see (on the monitor)? I've tried placing my digital camera near that spot (interior), and shoot downwards, but cannot see edge of bumper/tip of tow hitch -- which to me means this position will NOT work for backup camera?? THANKS!
Can BLING Get You Home?
Old 03-31-2004, 10:54 AM
max max is offline
H2Finally,
I do not use my camera for hooking up my trailers. I use it as a safety measure so that I don't back over kids or dogs (cats are ok). The wide lens gets a couple of inches past the hitch. Too much flash glare to post the pic of the view. Here's the camera mount..
Old 03-31-2004, 11:59 AM
JamesT's Avatar
See this limk. This is what I bought. Look at the H Cam. Very COOL!
http://www.hitchcam.com/
Old 03-31-2004, 12:49 PM
max max is offline
That's the best one I've seen. How much $?
Old 03-31-2004, 02:25 PM
H2Finally's Avatar
Thanks max. Maybe the wide angle is the key. How wide is your camera?
Btw, curious, if backing up cats are ok, why is your avatar Felix?
Old 03-31-2004, 02:33 PM
max max is offline
I'll have to get back to you with the camera info.I had a bunch of security cameras and played with a few different ones. Need to open the covers to get at the info (probably won't). Felix keeps moving and my turning radius isn't that great.
