Old 10-11-2006, 01:07 PM
sc2178's Avatar
sc2178 sc2178 is offline
sc2178 is on a distinguished road
Default what do I need to mount my front license plate on my H3?
Just got my plates today. There are 2 square holes up front but no bracket or any threaded inserts for bolts or anything.
Is there some sort of bracket for it?
Old 10-11-2006, 02:22 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: what do I need to mount my front license plate on my H3?
check in your glovebox and see if there are two small plastic plugs -- those pop in those holes, then you can use screws (which may be in there too) to attach the plate..if not -- your dealer probably has a ton of these and would just give a couple to you.
-Brian
http://www.hummerguy.net
Old 10-11-2006, 02:31 PM
sc2178's Avatar
ah I will check that out. Probably the same as the ones for the back plate.
thanks
Old 10-11-2006, 04:40 PM
jp's-h3 jp's-h3 is offline
You can also get them from any auto parts store!
Old 10-11-2006, 04:48 PM
sc2178's Avatar
no luck in the glovebox.
looks like a stop at AutoZone
Old 10-13-2006, 02:29 PM
H3.007 H3.007 is offline
Advance Auto sells these plugs. I remove my dealer vanity plate and plugged the holes with the plugs. They are very large in size. The shaft is about 3/8" OD , 1.5" long, and the cap is about the size of a half dollar. They look like black, streamlined mushrooms.
Old 10-13-2006, 02:44 PM
OR.........
SUPER GLUE !!!!!
RYD
Old 10-13-2006, 03:42 PM
[quote=RubHer Yellow Ducky]OR.........
SUPER GLUE !!!!!
RYD[/quote
I prefer "Duck Tape" or is it "Duct Tape?"
Old 10-13-2006, 03:54 PM
[quote=timgco]
OR.........
SUPER GLUE !!!!!
RYD[/quote
DUCKY TAPE
Old 10-16-2006, 09:26 PM
sc2178's Avatar
Well I went to AutoZone and they had a plate mounting kit for $0.99. It has 4 screws and 4 square nylon plugs that are threaded on the inside. Used two of them, they snapped right in the bumper and the plate screwed right on!
Old 10-16-2006, 09:35 PM
cool
Old 10-16-2006, 10:00 PM
AUH !!!
What I would give for some $ .99 cent screws...
RYD
Old 10-17-2006, 02:41 AM
QUACK (tape)
Any fix for a buck is a good fix!!!
Old 10-17-2006, 04:08 AM
westhillsat's Avatar
You should have had the dealer provide them and put them in, if the state you are in requires plates on the front and back - then it's the dealers responsibility to make the vehicle plate ready.
Old 10-17-2006, 04:48 AM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
If your going offroad, bend the plate to the bumper and put in 4 screws. Might save the plate
WWW.BCBI.COM
Old 10-17-2006, 06:13 AM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
AUH !!!
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
Old 10-17-2006, 03:41 PM
sc2178's Avatar
I didnt realize that it didnt have mounting provisions until I received the plates. also, I got the vehicle in Ohio and I now live in North Carolina so it was just easier this way
sc2178's Avatar
True
