Old 04-30-2007, 07:52 AM
JeffW JeffW is offline
JeffW is off the scale
Default Re: Which OPTIMA battery to use?
Sorry for the delay, I was sick all last week. Here are some pics.
H3, Boulder Grey, Cashmere Lux, Off-road pkg, Toyo M/T 33" tires, in-dash computer installed!
Old 04-30-2007, 01:52 PM
fourfourto's Avatar
Thanks for pics, looks tight to fit my light.
Maybe they have one with the posts more apart.
When Im ready I will have to look into it.
Old 07-12-2007, 07:46 AM
Originally Posted by JeffW
Here are some pics.
Hi JeffW,
I see you had to mod the battery box lid. How about the bottom tray--did you have to trim away the little tab/reinforcements (on the terminal / length ends or all around)? Did you mod the "puck" (where the bolt affixes the strap)?
My smaller Red Top with a BCI of 25 didn't require the tabs to be cut, but would have required the lid to be cut (if I reinstalled it). I also had to make a slight mod to the "puck", so the strap would tighten against the smaller battery. Now, I am thinking of upgrading to the Yellow Top. Weird thing is your model has 750CCA, but the same model here in Europe is 690CCA.
mountainbiker
Old 07-12-2007, 05:11 PM
Originally Posted by mountainbiker
Hi JeffW,
mountainbiker
Yes, I had to trim the back two tabs to about half their original width. I did make a modification so the strap would be snug. I didn't modify the puck, though. I suppose that might be a good way to go. Instead I just put some strips of lattice fence wood on top of the battery underneath the strap.
Old 07-14-2007, 05:17 AM
SHYANNE SHYANNE is offline
SHYANNE is on a distinguished road
is the optima battery reall really that much better and will it last that much longer with the extra cost it cost ?i dont know much about it ?
Old 07-19-2007, 12:52 AM
Conventional batteries don't like to be dishcarged very deeply. That will shorten their life considerably. Yellow top is a "deep-cycle" battery which is designed to be allowed to discharge deeper between charge cycles. If your power profile is unmodified, I don't think this is of much concern. In my case, I added a computer system that goes into standby when the vehicle is off, and continually draws 180ma in this state. That shouldn't be too much trouble for the stock battery, but I decided to play it safe so I don't have to worry if the vehicle isn't driven for a week or so. One time, after I installed the Optima, I actually left the computer running at full power over night and it started up fine the next day (with computer still running).
Old 07-19-2007, 08:22 PM
H3gtwn H3gtwn is offline
H3gtwn is on a distinguished road
I have run both Yellow tops and Reds. My experience is Yellow Tops do not like to be charged frequently. My wife's constant short trips tended to kill a Yellow top in less than a year or two. If your charging profile is frequent short charges, and primarily starting, then the Red top is best. 5 years from a red top is easy and they take the abuse of trail driving like no other battery.
If left disconnected the low self discharge rate means they can sit unattended for a year and still maintain a charge. They also do not vent gases, so that battery box and vent setup are not needed and they can be charged at a high rate that takes advantage of the 125 amp alternator in the H3.
My first modification to my new '07 was to place a Red top 78/34 into the battery slot.
