Old 11-09-2006, 11:45 PM
SR1355's Avatar
SR1355 SR1355 is offline
Default Re: RockRail Sliders Arrived.
HJ next time I see you I'll have to take a close look to see how they are built and mounted. The Rocky Road ones have three mounting arms made out of what looks like 3/8", the arms appear to be 1" solid stock to the under rails which are roughly 2" square, the outer rails are 1 1/4" round with 1/2" stock connecting them to under rails.
Paul M
SR1355
Old 11-09-2006, 11:51 PM
SR1355's Avatar
Close Up for Mounting bracket and arm:
Paul M
SR1355
Old 11-09-2006, 11:52 PM
SR1355's Avatar
Shot showing front two mounting arms, the top bolt hole on front plate is not positioned correctly:
Paul M
SR1355
Old 11-09-2006, 11:53 PM
SR1355's Avatar
Closeup of connectors between under rail and outer rail:
Paul M
SR1355
Old 11-09-2006, 11:54 PM
SR1355's Avatar
Installed:
Paul M
SR1355
SR1355's Avatar
Installed Two:
Paul M
SR1355
Old 11-10-2006, 01:17 AM
Wisha Haddan H3's Avatar
They do look good. Glad you were able to force them into place. I'm still up in the air between oem and rocky road bars. but these QC issues are a pita I don't want to deal with.
Old 11-10-2006, 02:58 AM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Talking Re: RockRail Sliders Arrived.
Just installed the RRO H3 Super Slider Rock Rails. Of coarse they sent the wrong bolts....but a quick trip to sears and sixty minutes later with a little sweat and some blasphemy they are on my baby girl. They look great, they weren't really that hard to put on, I even did it at night with a flashlight. They fit you just have to use a little TLC, I got all 12 bolts on.
Pictures to follow when I get to my camera.
The Goat
Old 11-10-2006, 03:42 AM
dochummer's Avatar
It might not have been positioned correctly if they had not been on the original set of rails that were fab'd for babhumv(?) - I have a set for the H2 without the extra plate, they said that they were going to add them to the supports/brackets and send some out to me...I just don't know how they're going to account for the brake line without the actual vehicle in front of them...
'03 H2
Old 11-10-2006, 04:09 AM
CrisB's Avatar
CrisB CrisB is offline
Paul, what did those rails cost you? I can get an OEM set for $500, I hear they fit fine.
Old 11-10-2006, 04:17 AM
SR1355's Avatar
Cris, they were alittle overv $400 including shipping. Even with all the trouble they still look great and I'm sure they stand up to slidin on the rocks.
Paul M
SR1355
Old 11-10-2006, 06:52 PM
I got my OEMs for about $350 shipped but I got a deal. The OEM are very strong and I have not had any issues with them. I am sure the RRs are plenty strong as well, I would just be concerned about the missing mounting point. Basically, by skipping that mount didn't they reduce the overall strength by 1/4? I will get a chance to check some out next weekend and look forward to it.
Old 11-10-2006, 11:42 PM
SR1355's Avatar
Yeah, I plan on adding skids to the rails os when they are off for fab. I'll have to holes elongated to address the missing bolt.
Paul M
SR1355
Old 12-30-2006, 11:13 PM
GPan099's Avatar
GPan099 GPan099 is offline
GPan099 is on a distinguished road
Installed my RR sliders this morning so I thought I would share an update:
Ordered them on the 15th and they arrived in NY on the 29th.
Fit was great, no issues with the holes not lining up. Still 3 mounting points,
2 bolts each.
Bolts were the correct size, though a bit long. Feel real solid.
Can be used as a step, though a bit higher than the normal step rails. (APPROVED FOR THIS USE BY THE WIFE.) I will probably install some kind of stick on material to improve traction when using as step.
Install done alone without difficulty.
So if you have been hesitating because of the quality control issues, they seem to have improved greatly.
