Old 11-13-2005, 05:14 PM
LAREDO TEXAS's Avatar
LAREDO TEXAS LAREDO TEXAS is offline
LAREDO TEXAS is off the scale
Hello
Has anyone install individual led markers? Their is a local shop that installs on the front of your rearview mirrors individual leds to blink with your turn signal (They do have to drill a hole for each led but they are water proof.) Anyone has thaugh about installing this as markers on the top?
I will try to get some pictures of how they look and will post them soon.
Anyone from LAREDO TEXAS?
Hello
Old 11-13-2005, 05:43 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
I installed them on the rear if thats what you mean. Check page two of the tech. topics for REAR ROOF LIGHTS started by Green Lantern. If your talking about the ones on your side mirrors, I saw some on E-Bay yesterday for cheap.
WWW.BCBI.COM
Old 11-13-2005, 06:44 PM
I just received confirmation from Muth that they will have turn signal mirrors available for the H3, starting early in 2006. They have been designed, tested and approved for production.
When available, I'll be happy to let everyone know. They are to notify me when the first set arrives, since I helped them out with some wiring locations, and harness routings.
Easy to install, and no drilling required.
Just pop off the door trim panel, pop off the mirror glass, run two wires (hot/ground) from inside the mirror housing, through the door to the turn signal wires and ground, then install new glass.
The new mirror glass has five or six LEDs that blink with the signals and looks like an arrow.
Muth makes most of the factory installed turn signal mirrors for GM.
http://www.kwmuth.com
Old 11-13-2005, 06:57 PM
Game Over Game Over is offline
Game Over is off the scale
hopefully it'll be a while so I'll have time to save up
Old 11-13-2005, 07:43 PM
HMRLVR
The principal would be the same as the ones you have install, but instead of having this side markers that look that came out a trailer you would have an individual led bulb kind of like the ones that come on the aftermarket alarms but this ones can be install on the outside due that they are water proof. You will have to drill individual holes for each led bulb you install, but in my opinion it would look much cleaner and you would only notice them when turn on at night. I will get some pictures of the product install on the front of the rearview mirrow for you to have a more clear idea of what I'm talking about.
