Old 12-04-2006, 10:39 PM
Default Re: Solution to H2 overheating problems
Originally Posted by GLBLWARMR
Is there any reprogramming that needs to be done to the computer when if you switch from the stock temperature thermostat? I swapped out one in another vehicle and because of the change I throw everything out of whack. The engine started running to rich and stalling out. I had gone from a 185 degree thermo to a 135 thermo. Once I switched back to the 185 thermo all the problems were fixed. Just curious if this was a problem with the H2??
Sorry for late reply. Holidays really messed up time. I would only lower the thermostat temp if I was in a normal condition with engine temp. and went to programmer that would in turn allow Me to run cooler thermo by telling computer you were doing so. Of course at same time getting the benefits of other options of programmer.
The only other way I would run cooler T-stat with stock tune is if You are in a hot temp part of the world and needed the cooler T-stat to try and get to a cooler engine temp and maintain a stock engine temp.
TAZ
