12-28-2006, 09:48 PM
Tire pressure monitoring through Onstar
did you guys hear, onstar is now gona be sending your tire pressures with your monthly reports, and i guess they will also be able to tell you at any time by pressing the blue button. no more guessing if your at 35 or 34 psi. i think its a pretty nice feature.
12-28-2006, 11:24 PM
Re: Tire pressure monitoring through Onstar
Are you sure its going to give tire PSI ?
I would think they could warn of low tire like the dash does .
I thought the TPS goes off at a low PSI like under 32,How can it tell exact PSI.
12-29-2006, 12:43 AM
I just got mine and it didnt say anything about tires in the report. Maybe its only new trucks or if your tires are flat like that guy said.
12-29-2006, 12:46 AM
Even if its minimal info. Onstar is a advanced information system that sets the H3 apart from  most vehicles. I love it!
12-29-2006, 01:42 AM
go to this link: http://www.onstar.com/us_english/jsp/ovd/index.jsp and click on the orange circle thats on the wheel of the car thats there. a thing will pop up on how its going to be shown. it shows individual tire pressures. dont know if its gona be available withthe h3 but i think it will. just because the pressures are not displayed on the DIC does not mean that the BCM does not know what they are. Just like with oil life.
12-29-2006, 01:55 AM
Since I'm a good boy and reading my owners manual (all 490 pages...(Including the index) front to back.... I did read that "The Tire Pressure Monitor is not a substitute for good tire care and checking your tires once a month.
Now Read Your Manuals and get that tire gauge out and start check-en
12-29-2006, 02:31 AM
or check out the sample email report: http://www.onstar.com/us_english/jsp...mplereport.jsp
manual? come on, i think i know how a car works, thats for reference not for reading (as a novel). why whip out the tire gauge when it can be done for you, i dont have all the time in the world.
12-29-2006, 02:42 AM
I checked the site he mentioned
and it implys (open to how you read it) that it will show indiviual tire pressure. It is a gray area though.
RYD
12-29-2006, 03:03 AM
Gray area? Ok, from what I know (and who knows it might be incorrect), but on the H3, the BCM does not read each corner, but each sensor, not knowing which corner it is located at. Which goes along with the fact that on an H3, if you rotate the four tires on the ground (no spare), you do not have to reset (reprogram) the sensors. The BCM still sees the same four recognized sensors, so it is happy.
However, if you mix in the spare, it now sees a new sensor, and does not see a known sensor, so you have to reset the sensors to be recognized by the BCM.
On those vehicles such as Caddys that do read each corner separately, and display the tire pressures for each tire separately in the DIC, when you rotate the tires, you have to reset the system, so the BCM knows the front right sensor is now at the rear left wheel location.
Now, possibly, inside the BCM there is a chip that is looking at each sensor as it was programmed, and if you don't reprogram after a rotation, it will be confused, but not know any difference since you don't do the reset. However, I have failed to see this on the GM Tech 2 scan tool, and usually, what Onstar is picking up is what can be read on the Tech 2. (Maybe I need to go back out and do some more digging on the Tech 2.)
So, if the BCM can determine which sensor is at which corner of the vehicle, then when you rotate the four on the ground, even though the TPM message stating a system problem is not displayed, you would have to reset the sensors to that particular corner of the vehicle.
However, as Viet Nam Vette implies, 30 days is too long to not check your pressures, even if a TPM message is not displayed.
I will be curious, but will not know unless someone informs me on the forum, since I canceled the worthless (my opinion) Onstar service, and told them to shove it up to where the sun does not shine.
12-29-2006, 03:34 AM
Yeeeeeeeeeeeeee....Haaaaaaaaaaaaaaaawww..!!
Naa....Naaa...Nin..Naaa Naaa....Told you so ..told you so...
The Man Has Spoken
12-29-2006, 03:42 AM
12-29-2006, 03:52 AM
12-29-2006, 07:54 AM
The Man Has Spoken
BABY!!!   , hehe  , althou the man did say "who knows it might be incorrect", which i doubt very much, but i think it would have been nice if that would have worked with the 3.
12-29-2006, 08:41 AM
i dont think u guys remember this, but I posted a few months ago about my low tire light. It came on as i drove it out of the dealor. I took it back and they claimed to have fixed it, but yet it came on. Now yesterday i took it back and every tire was at 30-31PSI. hell when i was driving, it handled really horribly, i was swurving all over the place when i hit 50mph. They were so lazy and insulting. Claimed the light would go off when I drive it more. basically they were trying to run me away. But i was pissed because it has been 2months now, and everytime I started her up, it would give me a warning beep. Anyway, they filled it, and I was still fuming. So i reported them for bad service and wrote a letter to GM. Anywho thats my rant.
2007 Black H3, Adventure Package, Chrome Appearance, Chrome Cross Bars, Moonroof, Tow Package, Chrome Tubular Assist Steps. "My golly, this is by far the best looking 2007 H3 you will ever never witness"
My H3 is gods gift to man.
12-29-2006, 02:48 PM
Confused...
Are you saying your tires were underinflatted and the system was doing what it was supposed to do? In this case the 33" tires which are supposed to be set to 35.
Or are you saying the tires were overinflated since they were the wrangler tires and normal is 30 psi?
12-29-2006, 02:50 PM
The Man Has Spoken
Remember, I said I was curious, and that maybe there was something in the system I was missing with the tech 2. So, let's wait until someone gets their first air pressure monitor via Onstar. It may also be something that would be as easy as a simple click of a byte that Onstar can perform via a simple download. (They do update the Onstar module via the cell lines from time-to-time.)
12-29-2006, 06:26 PM
Yeah your right...would have been nice if the 3 had that plus the H1's Central Tire Inflation System....now that would be cool for wheelen..
