Old 01-05-2007, 06:59 PM
leenigen's Avatar
leenigen leenigen is offline
leenigen is off the scale
Default Tough Cold Starting
I've got a 94 with a Jasper 6.2 L NA. Whenever it gets to be below 50 degrees or so its a real pain to start. I have to floor it and crank for a while before it'll fire. Then is starts with the huge cloud of smoke. Warm days are no problem and when I get the chance to plug it in there is no problem. The glow plugs and controler are all new so I know they're heating well. I've had a few other diesels that would start fine well into the 30s or even 20s. Any ideas what the probelm might be. I can't believe that's just the way it is.
Old 01-05-2007, 10:19 PM
ssgharkness020147's Avatar
Default Re: Tough Cold Starting
Have you checked the fuses for the glowplug controler? Is the wait light coming on? If so for how long?
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 01-05-2007, 11:04 PM
leenigen's Avatar
I think the controller is working okay. The light comes on for probably about 15-25 seconds. I have had other problems with the controller that may be related. It burnt up twice in the last year. The coil in the controler was shorting. When I ripped it apart to see there was black spot on the coil that smelled burnt. After the second time I checked the glow plugs and found two bad ones. After replacing all the plugs and controler, I haven't had a problem with it burning out since.
Old 01-08-2007, 10:26 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Low compression, cold advance not working, poor fuel quality just A few things you can check.
