Old 01-29-2007, 05:06 PM
tomp's Avatar
tomp tomp is offline
Default Price of Tire Air Pressure Sensors?
How much do these cost? Is it worth having tire un-mounted on stock wheel/tire to remove them, if upgrading to aftermarket tire/wheels?
Old 01-29-2007, 07:47 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
Default Re: Price of Tire Air Pressure Sensors?
Depends... You keeping the OEM wheels and tires, or selling them off..??
If you're doing what I did and had a set of offroad tires mounted on a second set of rims and plan on keeping the stock wheels to swap back and forth to keep the miles and wear off of the off-road tires, I'd leave the TPS with the factory wheels and tires...
If you're getting rid of the OEMS or are just planning on running the aftermarkets more, keep your TPS.. If you ever decided to replace them they are about $50 each if you don't have them.
They shouldn't have to completely unmount the tire to get it out, just break the bead.. Then of course put in a plain valve stem and re-seat the bead..
