Old 03-13-2007, 12:17 AM
zmanH2's Avatar
zmanH2 zmanH2 is offline
zmanH2 is on a distinguished road
Question Is a 2-ton Floor Jack sufficient?
I have a 2-ton floor jack similar to this one:
http://www.autobarn.net/mvpf-365.html
Now I know that the H2 weighs approximately 3 tons but since you are only lifting a portion of the vehicle when you use a jack, will the above be sufficient? (e.g. flat tire repairs / tire rotations / brake repairs)
HUMMER Like nothing else.
Old 03-13-2007, 02:41 AM
CslRkH2's Avatar
CslRkH2 CslRkH2 is offline
Default Re: Is a 2-ton Floor Jack sufficient?
I have a 3 ton jack and it seems to be on the light side. It could be the model I have, but just tonight it was struggling. Make sure it has a good lift, it takes quite a bit to get the front wheels off the ground even with stock suspension
