Old 05-04-2003, 03:48 PM
JPrusinowski JPrusinowski is offline
JPrusinowski is off the scale
Does anyone know the correct part number for the two bolts that hold on the tow rings located on the back bumper? I recently removed the rear mount tire carrier and the bolts are to long to use with just the tow rings in place. Tried the dealership and parts were not correct. Are the bolts for the tire carrier the same thickness as the originals or an upgrade? Any help is greatly appreciated.
P.S. Rear mount tire carrier complete for sale. Couldn't tow boat with tire mount in place. Swing away type improved version.
Old 05-12-2003, 01:22 AM
H2 Daddy H2 Daddy is offline
H2 Daddy is off the scale
The stock bolts and the tire carrier bolts are the same thickness. The only difference between the two is the length. Have your Hummer service writer pull out one of the correct bolts from a new H2 and show the bolt to the parts guy. The parts department should then br able to get the right bolts.
