Old 03-25-2007, 04:46 AM
H2 OHHH!'s Avatar
H2 OHHH! H2 OHHH! is offline
H2 OHHH! is on a distinguished road
Default Annoying whine!
Installed new stereo this weekend:
(2) JL Amps
Stealth box
replaced factory speakers
Notice a high pitched whine like noise that comes out of the speakers that mirrors the accelerator.
Anyone know might be causing this. Didn't notice it at first but wife was in the car and of course noticed it and now I can't help to notice it.
Old Chinese Proverb "Man who walk through airport turnstile sideways going to Bangkok"
Old 03-25-2007, 05:30 AM
wingnut2u's Avatar
wingnut2u wingnut2u is offline
wingnut2u is on a distinguished road
Default Re: Annoying whine!
Mine whines only when I accelerate but that may have something to with my supercharger!
Old 03-25-2007, 07:41 AM
twenty2's Avatar
twenty2 twenty2 is offline
sounds like a grounding problem with the radio. Find a new location for that grounding wire.
Old 03-25-2007, 01:23 PM
yup a grounding problem. try moving your grounds around till you find a spot that works..can be really anoying.. but youll find a spot that works.make sure its bare metal.. no paint .you can file the area down. also make sure all audio stuff ground is using the same ground. good luck.
Old 03-25-2007, 02:56 PM
thought this was about 3bies
Old 03-25-2007, 03:34 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
(2) JL Amps
Stealth box
had same problem, they make a ground loop insulater (i think that is the name) that goes in-line with audio av connectors that will solve problem, hope this helps.....if needed ill get more info for ya....let me know.
Old 03-25-2007, 04:59 PM
yeah its a ground loop isolator, which should help. but it would better if you could just find a good ground for everything.
Old 03-25-2007, 05:00 PM
Motohead's Avatar
Motohead Motohead is offline
bad ground and also make sure the power cable isn't running next to RCA cables. Can also do it.
Also might be coming from the Prius that you ran over...
Old 03-25-2007, 05:02 PM
H2 OHHH!'s Avatar
Great, thanks for the quick replies.
Old 03-25-2007, 06:33 PM
Old 03-25-2007, 07:36 PM
HummBob's Avatar
HummBob HummBob is offline
I thought this thread was about MY WIFE!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 03-25-2007, 07:52 PM
H2 OHHH!'s Avatar
Old 03-25-2007, 08:55 PM
emeldahay's Avatar
emeldahay emeldahay is offline
emeldahay is on a distinguished road
The annoying whine on my stereo always turns out be James Blunt.
Old 03-26-2007, 03:14 PM
JoeHummer's Avatar
JoeHummer JoeHummer is offline
JoeHummer is on a distinguished road
Wouldn't be about my wife. She refuses to ride since I took off the steps and have to give her a "hand" getting in.
2005 H2 Lux, Factory Nav, Chrome Manik racks, guards and side bars. 2 Ipod adapters (1 is a POS), Airaid, K&N filter, Magna Flow muffler, Hypertech III, 18" rims with Nitto Mud Grapplers.
