Old 03-30-2007, 03:53 AM
fourfourto's Avatar
Question My door chime got real loud ?
My door chime got real loud overnight .
Is that a factory chime or would that go through my eclipse system and the on star chimes adapter installed with the radio?
How could it be adjusted lower ?
Why would it change ?
any help would be great.
Old 03-30-2007, 07:55 PM
marin8703's Avatar
Default Re: My door chime got real loud ?
if you took out the factory radio then an adapter was installed to keep the chimes. So the chimes are not going through the eclipse but the adapter/interface between the eclipse and the wiring harness.
I used the peripheral, and i think it cannot adjust the chime volume, just the onstar volume, not sure.
Which adapter/interface is used in your truck? Check to see if it has an adjustable knob or something like that, if it does maybe it somehow was readjusted. Other than that I am clueless.
Old 03-30-2007, 08:16 PM
fourfourto's Avatar
Im not sure were they mounted it,there are some boxes added to the right of the radio and also I seen some inside the end cap on the dash(looks like they opened up a hole there behind the cap.
Ill have to call the installer if no one else has any ideas.
Old 03-30-2007, 09:59 PM
Someone stick a higher voltage battery in the hearing aid when you weren't looking?
Old 03-30-2007, 10:29 PM
fourfourto's Avatar
Im not as old as you It would be better to remove the battery
Freeking thing is loud though
I call the installer on monday and see were the setting is.
Old 04-06-2007, 09:16 PM
fourfourto's Avatar
My onstar also started to have a wine,and when I open the door it goes away.
I stoped by installer today and he looked at it .He said the chimes module is probobly bad he checked stock he has one .
He didnt have time today(friday he gets backloged)
I will bring it in on tuesday and he said it would be No Charge,he will send mine back.
He gave me a 3 year warranty on the system.
First time I had any trouble since installed 01/06
He only has 2 other guys there so Ill toss him $20.00 to buy lunch.
Old 04-10-2007, 06:01 PM
fourfourto's Avatar
Back from installer ,I had a bad onstar module.
He replaced it with a updated one.
Alls fine ,the chims are nice and low Yey!
Old 04-10-2007, 08:40 PM
Your not a bad person bit I'm warning you... "DONT MESS WITH OLD PEOPLE"
